Wireless IP Camera thread
Apparatus
Re
The Samsung camera is configured to work on dynamic IP address. If you look at the DHCP server of the router, you can find out which IP address is given out to the camera. Then, use a browser to connect to that IP address. When you do so, you will be asked to provide a private key, which is actually the password to assessing the camera.
So can you view using Robert Chou's IP Cam Viewer? Are you using ASUS router?
I've set up using Robert Chou's IP Cam Viewer but not getting a video feed. May be should ask Robert Chou anything else he needs to enter into his software for it to work.
geckoSG
Everyone have their own needs of PTZ or fixed. Areas of viewing, etc. Let's not get too emotional which cameras we chooses here and start doubting each other's setup condition, we all have a purposes why we do things in certain ways.
We all have a brand, model that we like for sure. But have an open mind and see which camera works better for individual
geckoSG
I think there is a bug in the firmware. I can't set it up if I use Fixed IP address for the IP Camera. I need to use DHCP dynamic IP address before it works. If I use the fixed IP address, the subnet mask keeps defaulting to 255.255.240.0 instead of 255.255.255.0, and the gateway keeps going back to 0.0.0.0.
Sounds like a same characteristic I've seen on one of those made in china cameras, which the developers did not think about the possibility of using fixed IP...
Hope they fix this up.
Dr_ARCHer
Yes I am using Robert Chou's IP Cam Viewer (both Android and iOS versions). And being an Asus fanboy, I am also using their routers (2 units of N56, N66, AC66 and AC68 each :D ).
I think you are confusing DDNS and DHCP. DDNS maps the ISP issued address to the URL. Previously, I was using DynDNS but now using No-IP. Asuscomm.com is Asus's version of the DDNS service.
DHCP assigns an internal IP address to devices requesting for it. Such devices have to be configured as operating in a dynamic IP address mode. If you click on the Devices connected on the Network map (or home screen) of the Asus routers, you can see the devices that are connected to the Asus routers on the right side of the page, and their respective IP addresses.
Apparatus
Do you require port forwarding in this case? Can you can post the steps here using Robert Chou's software? Thanks
Dr_ARCHer
To set up portforwarding in Asus routers (N66/AC66/AC68), click on WAN under Advanced Settings (left side of the home screen).
Then choose Virtual Server/Port Forwarding. Choose Enable forwarding.
Next you key in the information for your camera. Service name can be anything (preferably your camera name/location). Port range is the port on the WAN side e.g. your.url.com:xxxxx where xxxxx is the port on the WAN side. Make sure you choose one that is not used by any program/service. Local IP is the local LAN IP (192.168.x.x). Local port is the port to access the camera. Typically, set it to port 80 (HTTP port). Protocol is TCP. Then click the '+' Add/Delete button. Remember to click Apply after this. The router will apply the settings, which I think basically reboot the router.
You need to set up the DDNS service. For that you need to register it.
On the IP Cam Viewer app, choose the right Make and Model (Make: Samsung; Model: Samsung SmartCam). Host/IP would be the DDNS URL that you have chosen/set-up. HTTP Port should be set at the external port you have configured the portforwarding i.e. the xxxxx above. User is admin, and Pswd is the login password for the camera.
If you are using the Dynamic IP for your camera, make sure that you get the LAN IP address from the Clients list and then set up the Virtual Server/Port forwarding.
Note that this process on the Asus is almost identical to the one on Dlink DIR-655 (and probably other Dlink routers). I wrote one guide (complete with screen dumps) at the start of this long thread. You can refer to that.
Apparatus
Re
Thanks
Since I'm using ASUS AC68U router do I need to set up the DDNS and to register? I thought ASUS's DDNS is ipcameras.asuscomm.com?
Dr_ARCHer
Thanks
Asus DDNS is asuscomm.com. The first prefix is the hostname you choose. You could choose apparatus.asuscomm.com and this will be your DDNS host name. :)
Apparatus
Re
Ok followed to the letter using ASUS's DDNS but still cannot get it done.
It says cannot connect to the Host/ip and port
kopioboy
SD card on SineoJi Cam
I cannnot format my SD card on Sineoji PT331V cam.
I am using Samsung SD Card 32G CL 10.
Can anyone advise?
user109s
You can try to use pc or laptop to format first then put it back to let the cam formats. Hope this help. :)
Veron4
hi guys,
any player to play the recorded videos from vstarcam in which the picture and sound are in sync?
thanks!
geckoSG
hi guys,
thanks!
You can only use their own offline player or play it online via webui. No other third party app. If you had read marix's blog, they already told everyone not to depend too much on the video recording with audio
geckoSG
Try this, find your WAN IP address first, then test using WAN IP address to key into the APP, if you can connect in, means DDNS not working due to some reason. If cannot connect in, your Port forwarding is wrong. Then work on solving your port forwarding.
Dr_Archer had given a very detailed explanation on setting up the port forwarding already.
kopioboy
Tried before, cannot also
Suspecting only can use 4GB CL4 SD card
Bit regret to buy this Sineoji cam
Think the Dlink Cam are much better
geckoSG
Lolz. I think Sineoji got played out by their china manufacturer. Vstarcam can use class 10 somemore. But again, is ur microsdc ard genuine? Wanscam cameras shld b able to support class 10
geckoSG
Just sharing this email I've received today from MARIX... :s22:
"We have started our VStarcam PC & TECH SHOW 2014 Early with great promotion prices on our VStarcam product.
Get your T7835WIP @ $109! T7838WIP @ $119 & T7837WIP-AR @ $139!
While stocks last on our eShop @ http://marix.com.sg/?product_cat=vstarcam"
Dr_Archer... Your T7833WIPX3 is now $189 liao... Cheaper than previous price we MO :s13:
A summary of all the price tat I have saw at the online store.
T7892WIP @ $85
T7835WIP @ $109
T7838WIP @ $119
T7837WIP-AR @ $139
T7850WIP (Export) @ $159
T7833WIP @ $169
T7833WIPX3 @ $189
Refugees
Hi guys, I am looking for a security camera for my retail outlet (monitoring & surveillance). Any particular model/brand to recommend? This is my first time getting a security camera, would need more advise.
Will be better if it's plug & play (save me the hassle to configure all the settings)
Wide angle?
Able to record so I can view previous days recorded footage when I am free
Possible to listen to what my staff is talking via the security cam?? (Not important)
Lastly, I believe I need to sign up with any telco for wireless broadband for the camera to work right?
Thanks!
geckoSG
Yes. Internet is a must. U refer to the price i shared 1 post above ya. Pricing is attractive, n yes u can eavesdrop on ur staff as well. Can also do recordings playback
