Wireless IP Camera thread
barrios
sineoji,
what's the cost involved ar?
eg:
3 x 49*
3x SD card
electrical (i guess $50)
is there a central server or something?
any bros here from there? rather than i call the company as a cold customer, i might as well give you the business right?
Their prices are quite fixed. You can get the IP cam from Challenger, member price is cheaper. 3 yrs warranty. 64GB microSD card can store about 20 days recording, 128GB about 40 days.
sk0065
Dean just called me.
very professional.
back for some advices.
which model to get ar?
492, 495, 497,593
Gribber
very professional.
492, 495, 497,593
the only problem i have with Sineoji is the price because other competitors offer better IQ [720p vs 1080p] at similar price (treat it as paying for service).
Depending on your needs but to me, wider angle is better.
barrios
very professional.
492, 495, 497,593
Other than the price, do consider the wider viewing angle, ability to take 128GB microSD, the responsiveness of the mobile client, reliability of 3G/4G connection and very importantly, the support.
desatans
Update for my zafego.
Marix has contacted me and login to my cam on 27 Oct using guest account to check the issues reported previously.
As for night vision clarity, I have also tested the cam which is mounted on my ceiling in full darkness. Below are some snapshot from the cam in HD mode.
Reply from Marix was, will forward my case to their Swedish counterparts to study and get back to me asap.
desatans
Desatan, thanks for the feedback, our team is in work with our zafego partnership and factory to fine tune the sensitivity of the IR Sensor. As seen in the photos, our IR kicked in earlier than VStarcam's T series. We will be fine tuning this and releasing a new firmware soon.
As for night vision clarity, here's a recent image we have taken
Hi, your night vision snapshot and my night vision snapshot from my last post looks different? Or is it becos everything in your photo was within the 5m IR range? But my tv console also within 5m range.
IU_leon
don't think they provide also.
paging for Dean to respond.
Thanks Gribber.
We offer value add service to set it up at no cost on your mobile and PC. We will perform a live demo at your residence during the setup so that it gives you the background of the video quality and the responsiveness on wifi and 4g mobile data.
We do not rewire any electrical trunking as you will need a license electrician to do that.
Gribber
i noticed something.
both Sineoji and Zafego only show night vision using mobile.
I have yet to try Zafego so can't comment.
For Sineoji, its night/day vision looks decently sharp on both mobile and computer but the recording isn't - the compression used is to save storage space but for people like me with luxury of storage, i have got no option to make the recording settings to be what i see as the live view.
Dean, if you have any solution for this, do gimme a ping. Thanks.
Gribber
no offense, it looks damn different.
barrios
1st stream resolution is 1280 x 720. 2nd stream is only 640 x 352. Save space on memory card.
marixsupport
Hi, we will do a 1 to 1 exchange for you at your place and investigate your current camera back in office in the same storeroom.
A sincere apologies for the delay
Gribber
up for service. :s12:
looks like Sineoji is forcing other players to up their game. :o
barrios
i have configured the recording to be on first stream as well. Same result.
I configured it to record from First Stream and the result is same as viewing live which has good sharpness. However, the recorded video shows more "skipping" at 6 fps and 6 keyframe interval (First Stream default setting). Of course, we can change the setting to higher fps and keyframe interval, but it tends to revert to default by itself after a while.
Gribber
then probably, I am asking for better IQ then.
Video Settings
Resolution: 1280x720
Bit Rate: 6144
Maximum frame rate: 30
Key frame interval: 60
Bit Rate Control: VBR
Video code quality 1
See the difference
Live View
From Recording Video(VLC)
Imo, it look "washed" than looking from live view. Both were played on a 23" monitor (100% crop)
Sineoji got way to fix it? :o
vvaness40
sineoji leon, my relative is running a 24 hours food stall in Katong and I have recommended her over to you as she was enquiring about the camera when she saw it at my home during weekend. She was asking if you can help to install at 10 pm in the evening as this is the only hour with less customers ? PT492 model is sufficient. I have PM you her contact.
IU_leon
Thanks, I have contacted her and arrangements have been made to setup the ipcam at 10 pm tomorrow night.
roaminggod
Recently got a Sineoji Cam from Leon (Dean).
Superb service I would say, hussle free installation.
The quality of the image is good, meets my expectation.
The control of the cam is smooth and fast, compared to my previous ones.
The only problem I have is the viewing angle, seemed a bit tilted to the side, but again, it turns 350 Degree horizontally, so I think I can live with that.
I think for those who doesn't know IT or network well, just get a Sineoji cam from Leon. No regrets.
His number is readily available on the Sineoji website.
IU_leon
Video Settings
Bit Rate: 6144
See the difference
Live View
Hi Gribber and barrios,
We are working on a firmware which will allow you to record in first stream mode. As soon it is released for DVT, I will upgrade your cams online and do let me know your thoughts.
Cheers !
desatans
Hi, from the sienoji website only 593 offers wide viewing angle. But their estore doesn't display this model and price. Any idea whats the price for this?
Thx.
