Wireless IP Camera thread
sgnimo
Sgnimo
We do delivery from Mon to Sun 10 am to 9 pm. Pls indicate a note that you wish to have it deliver at 8 pm. Do take note as delivery comes with the installation, we will assist you to set it up on your phones as well as your computer.
PT492V supports only 64GB micro SD whereas the PT495V supports 128GB micro SD.
Here is a comparison chart which helps you to understand better.
Got it. Do you have a demo where I can see the difference between PT495V and PT593V? As I want to monitor my dog in the living hall, hoping to cover as much will be appropriate.
anil001
Thanks Dean from Sineoji.
Thanks for coming to my place and fixing the camera sharpness. I appreciate excellent support. Never heard on site support for IPCAMS ever before in Singapore.
I bought 2 593v cameras and happy with the quality.
IU_leon
Hi anil001
Glad to hear the Sineoji PT593V serve you well. Thank you for using Sineoji ipcam
IU_leon
Hi Victor
You placed an order for the Sineoji PT593V. We delivered it to your residence this evening and assist you to setup on your android phone and computer so that you can access remotely from your office to view live and the recorded video in the sdcard via your laptop.
Thank you for using Sineoji Ipcam
dreamchild72
Hi Victor
Thanks Dean for your great service.
marixsales
Dear Perrin,
Thank you for introducing more people to us, our installation is on schedule for all your community dwellers and we are pleased to hear the positive feedbacks.
We wish you peeps all the best for your new EC, its fabulous design in the North.
MARIX Sales Team
IU_leon
Hi anil001
Hi anil001,
Thank you for placing an additional order of PT495V. We will be coming over to your residence this evening to set it up in conjunction with the Sineoji HomePlug Wifi Extender as the camera will be residing a distance away from the main router where the wireless is weak.
SSagey
Hi,
Can anyone suggest a IP camera for a school project that I can connect it to the school's wifi network without using any network cables (wireless) and is able to view/control it remotely through custom application? Foscam seems to be able to do remote viewing and control though CGI. Not sure about the wireless connection though.
I had emailed some of the companies that I have seen on this thread, but unfortunately, no one replied. It would be great if someone can help me out on this. :)
@geckoSG, does the 2 models that you bought from Taobao happen to be able to do what I've mentioned? The prices for them sounds like a good deal.
IU_leon
Hi,
SSagey,
Remote viewing via CGI can be provided from our end. We have deployed about 15 cameras to an educational institution, however, they were using our PC apps to view the 15 cameras online.
If you wish to have CGI, it can be done. Can you provide me some info on the custom apps that you wish to incorporate the CGI to the custom apps ?
SSagey
SSagey,
Sure, how do I get in touch with you? Just for clarification, I'm only getting the camera for a student's project rather than for installation at an educational institution.
Razorsharp87
Hi,
Was wondering if there is any webcam that can record without requiring wifi? To view the videos, possible to use adhoc wifi from the laptop to do so?
Thanks!
localITguy
Suspended
Hi,
Thanks!
Sineoji's IP Cam do not require any wifi to record and it will be recorded in the SD Card.
you have to view it by removing the SD Card and loading the SD Card to your computer or do it via a local network where the IP Cam is connected to .
SSagey
@IU_leon, your message box is full. Kindly clear some of the messages so that I can send you some information. Thanks!
Razorsharp87
Thanks for your reply. May I know if connecting my laptop to the IP cam via LAN cable should enable me to retrieve the files? Will I be able to configure the IP cam to connect to my adhoc wireless from my laptop to view the files?
Thank you for your time to reply! :)
IU_leon
Hi Razorsharp87
By connecting a lan cable to the ipcam via your laptop without wifi , yes you can browse and retrieve your sdcard contents.
I have not tried the adhoc wifi but I have tried on a mobile hotpot router which it works.
unlimitedz
Unlimitedz
Thanks again for using Sineoji ipcam. Do not hesitate to call me if you need any assistance.
Thank you bro once again for making a trip down specially just to install the program into MAC labtop.
Cheersz mate!!!!!!!!!!!!!
sgnimo
You fellas from Sineoji are awesome.
Excellent camera and I am satisfied with it. Very much appreciated for your time to install it at my dining area and showed me on the intuitive steps to use the mobile app.
Thanks again. God bless !
geckoSG
Tomorrow, I shall give you guys more details on those cheap ip cameras. And give you guys contacts whom will setup your IP cameras at only $50∼$80. So your costs will be cheaper than any local brands With free installations.
Setup will be done by IT guys around Singapore. I will also provide links to cheap homeplugs that will work as good as those sold in market
