Wireless IP Camera thread
cherryade
based on my research there is no cloud server or cloud function on this camera, you might have been scammed bro. ( Don't take my word for it just yet, until i can actually verify the exact model )
which also explains why the video does not work after you removed the sd card.
can you please take a picture of the product and maybe the box, so i can help to see if i am able to find anything?
Apologies, due to post count Im unable to upload links or images..
But I found a sticker on the back of my camera with the model number - V380-Q5, resolution 720P. The seller did not provide me with any box when he came to install and mount for me.
Yup I'm also suspecting that it runs on the SD card instead of cloud.
His reply was: The micro sd card is being converted to be a micro chip for the camera technical support and use it as a backup. As this is a security camera, we need to have this security measure to ensure backup when there is a failure to the internet. I believe you have pulled out the microsd card to realize that the storage place immediately disappear, that is why the microsd card is being allocated to the camera. Once you pull out, the access is gone. Naturally the storage will not be shown.
He also told me that cloud storage function is the "download" function whereby Im allowed to download the footages from my mobile phone and challenged me to go to Sim Lim to request their sellers to show me that microsd card cameras are unable to download the footages directly to mobile phones.
Kind of doubt much of what he told me.
And now to think of it, he told me that this camera is 960P! When the sticker says otherwise ._.!
localITguy
Suspended
Hahahaha, downloading of the footage is not cloud, almost every IPcams allows you to download the footage via App. ( LOL)
there is no cloud function, all your footage are stored in the MicroSD Card. period.
You have been lied to
cherryade
Oh dear. Okay thanks all for clarifying! Now I know.
harky
ehhhh
cloud storage cfm is not your mobile or sdcard.
cloud storage is a online storage managed by a hosting company.
the video cfm is store in microsd card.
i think this seller use the wording wrongly.
* remember to change password of ur ip cam
earthlink
Thanks Dean for the help. Works fine after having it mount upside down.
You mount upside down on the ceiling or wall ? using the bracket provided I presumed ?
Grab the sineoji 713V online, video footage is really sharp, never need to pan it, it covers my entire hall including the dining area.
cherryade
ehhhh
Guess I've been lied to. I told him I wanted to try inserting my own SD card to see if the storage space is in the SD card and he threatened me that removing the SD card and replacing it with my own will void the warranty of the IP Cam. Yea now I know, so much for trusting blindly, thanks guys ;)
Yap initially he told me no need to set a password but I felt insecure and set it as soon as he left.
I've also clarified with weiskytech and V380 have no cloud storage options at the moment. Hopes the rest with the intention of getting this cam beware of sellers claiming that the cam has cloud storage functions and forces you to purchase the storage from him!
evq
who is the seller?
harky
How much you pay him in total?
Most of the IP Cam can set up by your own.
better change all your password where you had tell him or it is default.
I remember there is a site where it expose all IP Cam who did not change password of all over the world lol. Forget which site liao.
There is no sticker pasted on your SD card Or between Cam, even you remove they also don't know.
cherryade
I bought 2 cams and 2 "storage". Cam is $190 each, the storage is $55 each. Price paid includes installation and mounting.
Yap. Ended up i reset my passwords to my wifi as well as the camera. Lucky if not free footage of my home ._.!
What he told me was that if i removed the SD card, if there was a upgrade to the camera i would not be upgraded. Anyways I cant count on his words. If i need a bigger SD card Ill just purchase as well.
cherryade
where did you find him?
you have been ripped off..
I definitely have been :s11:
Found him on facebook. One of my friend had it installed with him and encountered no such issue. He told me that mine would be different from my friend's one (upgraded to cloud storage and improved resolution, 960P instead of 720P).
localITguy
Suspended
960P my ass, LOL
the model number clearly states its not.
harky
Wow, really got chop carrot liao. Even my less than $100 Cam also better than your. The only thing is no mounting. All is DIY. Even mounting you also can DIY le.
cyberian
So far only Netgear Alro is using cloud to store recording and all their cam no sd slot.
