Wireless IP Camera thread
reflush
finally, i joint ip camera club :)
bought my first ip camera, dlink - fix camera (forget the code :) )
so far ok and plan to cover all angle of my house :)
i notice, most people buy pan+tilt camera.
can share why you prefer pan+tilt type compare fixed?
apengrg
Looking for an IP Camera.
Anyone bot from Dealextreme SKU 26358 ? Looks
like a Foscam clone price $us 64.80 free shipping.
I hope its a good cam cos it has alarm I/O so
i can control a light and auto gate.
Any inputs?
shawn_sboi
Sorry reply late, seldom online now. If the wan ip is the ip of your RG, means your RG is not in bridge mode. If it is in bridge mode, your dlink should be the one with the wan ip. (Something like last time ADSL dial up days, Thomson modem as bridge, while the ADSL userid/pw is entered at the router side.)
I believe your case the RG is not in bridge mode, or for some reason cannot be in bridge mode. Why don't you try connect your cam to the RG instead to the dlink, or if must connect to dlink, set it up as a switch.
Thanks spell!
i followed lester chan blog exact steps and same.. seems like starhub doesnt allow bridge mode on RG? or is it my fault for doing it wrongly. maybe i will go research on this! however i will try connect my cam to RG and do my DDNS on RG to see if it can work ^^
superman888
Hi Guys,
I am looking for an IP camera which able to continuously record video onto USB drive or SD Card, IP Camera will wireless network will be an advantage.
Anyone know of such IP camera available in our local market?
Please recommend it and where to purchase it.
Thanks.
Dr_ARCHer
I guess if the field of view (FOV) is narrow, a fixed position camera will not be able to view everything. The advantage of a pan-and-tilt camera is that you can change the view of the camera to cover a bigger area e.g. a living/dining room.
For me, all my cameras (10+) are PT ones. I find that it is difficult to position any fixed position camera to be able to cover the whole room. For example, I need to put the camera in a corner, but there is no power point there, or where there is a power point, the camera cannot cover the whole room.
Dr_ARCHer
Hi Guys,
Thanks.
Several models have this capability, including Trendnet, SMC, Foscam, Dlink etc. So far, I find Mediapro (5th floor, SLS, 2 doors away from Laser) has a very wide range of wireless IP camera. You can download their priceguide at
http://www.mediapro.com.sg/PriceGuide.pdf
reflush
btw anyone have test side by side camera base on mjpeg and mpeg4?
can share which one is better for:
- live view over internet
- recording and playback
superman888
Hi Dr ARCHer,
Sorry...newbie to IP camera.
Which one you can recommend where I can record directly to USB drive (without PC or wireless connection)?
Which one you can recommend where I can record to SD card?
My preference will be USB drive since can record longer video (continuous), not those motion detect video.
Thank again.
Dr_ARCHer
Hi Dr ARCHer,
Thank again.
What is your budget? If you don't mind a fixed view camera, then Edimax's IC-3030iWN @ S$189 allows you to record to an SD card. If you want pan-and-tilt function, then the H series @ S$229 is a good choice. Further up in price is the Edimax IC-7010PTn (S$369), Dlink DCS-5230L (S$429), Dlink DCS-5635 (S$1088), just to name a few. Note that they all record to SD/microSD. Not sure if there are any models that allow recording to USB directly (unless via a USB drive attached to a router).
Lit3s
I have 3 units of the Foscam....i always have a problem in which it seems maxonline dynamic ip once auto changes, my IP cams would be down.
I always have to go in to my portforwarding settings to change the new IP address in order to work.
Anyway i can set it to auto update to move according to the dynamic IP address?
Dr_ARCHer
Are you using a dynamic DNS service? SUch a service update your URL with the latest IP address assigned by the ISP.
Lit3s
i did use dyn free host...installed dyn updater as well...however it seems to show its updated but i always still face the same issue..:s27:
Apparatus
RE
I've 10 dlink cameras of various models at home.
Before starting decide how many and what types of cameras you require and your budget. Would one brand of camera be your best option or a mix of brands? Consider the troubleshooting, service support and the softwares available for viewing (ALL the different brands of cameras if you decide to go by this option) on your handphone, notebook etc. Ask yourself - do you require every inch of your house to be covered (or just adequate coverage) and what detail you want to look into the picture?
Firstly, fixed camera is cheaper than PTZ (pan-tilt-zoom) camera. Assuming you want to save costs then installing many fixed cameras at strategic locations with good initial planning (like power point locations, wireless vs wired, angle of coverage etc) and with one or two PTZ cameras to cover dead areas will do a good job. There's no need to install all PTZ cameras in your home.
One thing to note. If the PTZ camera is panning then it's useless to record video. Fixed camera is better at that.
For camera with small field of view (FOV) you can attach an external small, lightweight wide-angle lens on the outside like what I've done. This will help to reduce the number of cameras required too.
An additional point to note is that foregt all those "low" light cameras if you want to see/record in low lighting situation. Only IR cameras are effective for this job. You can add external IR light if you find the camera's IR is no strong enough.
:s12:
reflush
i use dlinkddns.com service, but i got email from dyndns.com said my ip is block because of abuse use.
now my cam is not able to see from internet anymore :(
any idea how to fix this?
i use belkin router and dlink ip-cam.
only first day i can see my cam from internet use xxx.dlinkddns.com
after that i need to do nslookup xxx.dlinkddns.com to get the ip address, then type it with the port i open in browser to able see my cam.
is my router not do the job update the ip or i should not do nslookup or how?
thanks for any guide/ info.
Apparatus
I think it's better you check with DLINK
superman888
Hi Dr ARCHer,
Thanks for all the information. Indeed very helpful to me.
On the IP Camera, how about Prolink PIC1005WN?
If I am not wrong, the PIC1005WN can record continuous video instead of motion detection snap shot offer by Edimax, Dlink, etc?
Any comment are welcome?
reflush
btw anyone view ip-camera over internet from different location at the same time with different user?
example:
-login to ip camera from yishun use user a
-login to ip camera from bugis use user b
Dr_ARCHer
Hi Dr ARCHer,
I haven't tried the Prolink IP cam, so I can't comment. However, recording continuous video would take up a lot of space. Do you really want to do that? Review the recorded footage is also going to be tedious and boring.
Dr_ARCHer
example:
You can do that if your IP camera allows you to define multiple users. Some IP cameras allow you only 3 users: visitor, operator and administrator.
geckoSG
reflush,
Pan/Tilt wise, you can also consider VStarcam H6837WI too. Can also record to 32GB MicroSD Cards. Price also $229. Up to 7 users viewing, 3 diff profiles. Running on H.264
