Wireless IP Camera thread
woaoww
Where to Buy Wyze Cam locally in Singapore
Hi guys - looking to buy Wyze Cams here locally (want to see the product before), is there any way to get it from Sim Lim or elsewhere ? Can't find anything online on that topic ?
Otherwise, do you know online retailers who would accept 'Change of mind' returns ?
Cheers.
Tyer
No. There are usually apps for the IP cam that you can on your phone/tablet for LIVE view. If you need recording, you can use SD cards usually. One time costs, compared to cloud. If you need power supply, then you better get an electrician to help you make a power point. Otherwise see if your IP cam can work on power bank. Just my suggestion.
Dave27
How to configure tinycam to connect to my sineoji ipcam?
Must it be pro version? I dun mind paying but I was just trying the free version n got no idea how to setup
Posted from PCWX using ONEPLUS 5T
Contact Dean from Sineoji, my sineoji cams were installed by him when I bought it. What I really like about the cams is the responsiveness when I view it from overseas, the connectivity is fast and smooth. I have both app, Sineoji app and tinycam app.
lousydrinker
Yes you can download the recorded history from your sdcard to your PC.
1. Identify the ip address of the cam. ( You can either use your iPhone sineoji app or the utility tool from Sineoji website).
2. Go to your chrome Web browser and enter the cam up address in this format.
Example 192.168.a.b:8081/SD
3. Login your cam username and password
4. Go to folder REC
5. Download the files you want.
I cannot access to my records, seems like some plugins r missing
lousydrinker
I managed to get the tinycam working but I cannot connect to tinycam if I not connected to same wifi
purpleberry
Any xiaomi ip cam users here? About half the price of sineoji but downside is viewable by phone unless you install bluestacks.
goodwin
Using the tinycam app, you need to subscribe to a ddns service to redirect your Sineoji ipcams to the ddns host. Then you need to port forward the IP cam IP static address in your router. That's how it works.
If you are using the Sineoji app, this is not required. Sineoji ipcams is almost zero latency, thumbs up , regardless whether you are using either of the app from my observation so far.
goodwin
Means your IP cam address is incorrect or your port is wrong.
To get your Ipcam address, download the sineoji utility to your windows desktop. Open it and run the IP cam finder. Tap search, you will see an IP address and port number.
Go to your chrome web browser, enter the IP address and port number in the address bar, not in Google search bar. Example if your IP address is 192.168.1.10 and port number is 8081, enter 192.168.1.10:8081/sd in the address bar.
You will see a folder rec. Open up, and you should see all your clips there. If it is not there, means you have not turn on the recording function in the app.
Check the sineoji app, click i symbol, sdcard. Make sure sdcard capacity is not zero. Recording time must be on.
I used chrome, IE and Firefox, all cannot work
erwinrommel
I am deciding between dlink camera and sineoji. My previous dlink dcs 5222L is faulty and is looking to replace one...
The camera should have micro-sd card recording, night vision, PTZ and most importantly, the app has to be user friendly because my dad and mum will often be accessing it. I am leaning towards sineoji due to the great support and user reviews here but I am unsure how the ios sineoji app is.
Yod4
So i just changed my fibre provider to Singtel and have a new SSID setup for my network.
I did a reset on my Sineoji PT714 but wasn't able to detect the camera after that. Am i missing some step along the way?
Ows
anyone using Arlo Pro 2 or DCS-2802KT? or any type of battery operated camera?
goodwin
The earliest version of the sineoji iOS app was a little buggy... Following the release of iOS 11 onwards, the sineoji app has updates and that ultimately fix it.
But I must give them credit for their after sales support..
goodwin
Follow this steps which were given by Dean before
Connect a Lan cable from your router to the camera
Then open the Sineoji app
Click +
Click search
Select the cam ID
Enter password as admin
Click save
Then the camera shows online
Then click the small i symbol on the right
Go to WiFi
Choose your WiFi
Enter WiFi password
Click connect or save
Look at the camera, if it starts rotating, remove the Lan cable. Wait for 2 minutes until the camera status says online in the app.
Follow this steps
Wait until the cameras says online on the app
erwinrommel
I see. Thasnks.
Any recommendations for which sineoji models? Does it have motion detection? i only want it to film when there's motion.
Hot2002
For sineoji IP cam sensitivity setting, is level 1 or level 9 most sensitive ? Tried searching the user guide but to no avail
goodwin
I see. Thasnks.
I saw on Sineoji website that they have new cameras with Face Detection include a 180 degrees wide angle, PT818V. The PT816V is 142 degrees wide with Face Detection.
