Wireless IP Camera thread
Reechet
I've been experiencing this since last year Sept 2019. Whilst Dean has been very helpful, the intermittent connection remains unresolved.
After resetting all my Sineoji cam and Asus Router, problem remains - especially trying to connect via M1 4G will make my blood boils.
I'm on 700 series...... not too sure if upgrading to 800 series would resolve the issue.
Anyone sineoji offline? Is it because of their server or my internet? Both my camera down
harky
If you can access @ home using same network but not outside
If you know how, you can do port forwarder @ your router and change the ddns setting inside your Cam to use free ddns so you can access it
Some good router come with free ddns.. If have, than no need to register free one.
I don't have Sineoji Cam but my Cam has similar setting with Sineoji one
Hot2002
800 series cannot configure the high port number. So u are dependent on Sineoji apps
Biodhe
Hi all!
I'm looking for recommendations of a good IP Cam for my home to replace my current TPLink NC450's. I have been using the NC450's for the last few years and they have served me absolutely perfectly all this while except that I now find myself in a position where I need to replace one and add one more to my system. Unfortunately the NC450 is no longer in production and I cant find any legacy stock locally. TPlink's updated offerings(kasa & tapo) both use 2 different apps and lack much of the functionality the NC450's had, which is a no go for me.
The camera system will serve 2 primary functions, 1) Home Security, 2) Child/Baby Monitoring. I have tried a few different brands of ipcams over the years and have put together a pretty specific list of requirements, all of which the NC450's fulfill with the exception of 1080p video.
1) Must be at least 720p, 1080p is much preferred though, 2020 and all.
2) Must have ethernet connectivity as an option, though if u have a wifi-only cam that you absolutely swear by, I could be persuaded to look into it. Most current gen IP cams operate wifi-only and frankly even with my extremely overkill mesh wifi AC network with static IP's assigned to each camera, I have yet to find a wifi-only cam that is reliable. Every cam I have tried in the last few years(I have tried quite a few, NC450 included) will drop signal/lag/freeze on and off occassionally while on wifi-only(even viewing locally) and that is not acceptable to me. The NC450 works flawlessly on ethernet though.
3) Must have 2 way audio/mic.
4) Must have Pan/Tilt, optical zoom isnt necessary.
5) Must have a web setup interface or at least the ability to somehow configure static IP addresses per camera.
6) Must have a mobile app for remote viewing or at least be compatible with some universal IP cam app of sorts, such as TinyCamPro. From my testing, DLink's 8525 and TPLink's Kasa and Tapo are all not compatible with most universal apps.
7) Must have microsd storage, I'm not a fan of cloud storage.
8) Must be able to record continuously on a loop. I was actually rather surprised to learn when researching replacements that many current gen IP cams, even those with microsd storage, only record a short clip when motion/sound is detected and have no option for continuous loop recording.
Recently I tried DLink's 8525LH and looked into a few other brands' top offerings and they all seem to fall very short of this requirement list so any other recommendations would be greatly appreciated.
Thanks in advance!
P.S. I realize this is a "Wireless" IP Cam thread and I'm looking for one with ethernet but I have searched the forums and dont see anywhere else more appropriate for my question.
harky
I using Wanscam.. seen to be do what u want LOL
cheap also.. u can google on it.
and i think u can look for cam with ddns support.
Hi all!
Thanks in advance!
Biodhe
and i think u looking for cam with ddns support.
Nice, I looked it up, it's an ONVIF cam so it will definitely work with my app, and seems to have everything i need, very affordable too! Thanks for the recommendation!
Hot2002
Sineoji 700 series meets the list of requirements but it’s kind of legacy now. I have 5 cams. I have to make warranty claim on 1 of it
harky
U can get Wanscam HW0021 or Wanscam K21 which is 1080p.
actually if u notice, they look similar to Sineoji cam :p
i bought few yr ago.. the model seen to be same. it 1080p, i also had one which is WANSCAM HW0046 960P..
so far so gd.
Hot2002
so far so gd.
I guess they are all OEM. Thanks for sharing!
Mecisteus
Personally, I had used 2 Foscam cameras for many years.
They can connect by LAN. Configuration is the old school type.
Now, I move on to Wyze. Unfortunately no LAN. But configuration is so easy.
If your wifi connection is strong, there won't be any concern.
Wyze is way cheaper than Foscam though.
ksksksks
Wyze just connect up very fast. Even when outside and using 4g data.
Just bought the Xiaomi wireless camera. So far so good as well. Hopefully the battery is really 100 days =:p
https://shopee.sg/product/133942249/3615858089?smtt=0.0.9
mr168
I have given up using the sineoji app to access my ipcam, using third party app now. I set up port forwarding. Using tinycam pro app to access.
Hot2002
U need to configure your home router to do port forwarding as well
Not sure of the cost of static ip. An alternative is to get a smart power socket. I can access my smart power socket remotely via it’a apps and show the wan IP address
Within this thread, some pple have shared on configuring port forwarding
