Wireless IP Camera thread
harky
Hi can check how to do the port forwarding? Just change the router but realised the person in charge no longer contactable .😩
Your router need to set that IP to post forward.
harky
I have a small cd but no cd player to play . My laptop don’t have a cd rom
i been a while i install so i actually forget..
hmm i think u need to connect the cam (Wire) to ur router first to find the ip and access the cam to setup something inside.
something like this
nt sure if u can find using wifi a not..
try to download search tool IP (nt sure work a nt)
http://www.easyn.com/IP-search-tools.html
roughly remember i do ddns (FREE https://www.noip.com/) and do some setting on the router
usually router ip is hidden tht why u cant access outside network, so u need to port forward and setup a ddns..
some router had ddns inside.... (i think ASUS one has) so it easy just reg and setup and it done if nt wrong.
sineoji is using old technology, got gd and bad.. the only i like is i can view cam from browser which save dataplan haha, new one cannot.. must use mobile :( :(
now i use xiaomi 2k cam liao ahha
Marple
something like this
roughly remember i do ddns and do some setting on the router
Hi thanks , the big headache is that I change my router and now the IP Sineoji cam is still under the old router settings. Once I connect ethernet cable from the camera to the new router and do reset, where shall I go to reconfigure the IP cam to the new router settings?
harky
lol
once hoot up ur cam and ur router... u got the ip thn access from tht ip from browser and go in..
actually u can hoot up and see if ur router can detect the cam IP a not..
i think down because Sineoji ddns gone.. so u cant access it..
Marple
lol
Hi that’s the other brand camera search tool. Now that Sineoji brand has gone into history, where shall I search?
harky
should be able to search.... i think is universal one
if not u try to rest and hook up see ur router can detect a nt
Marple
Hi I connect the lan cable and I see connected device. But connected does not mean configured. Also the camera in the Sineoji app is still offline. I need to configure settings but how to do that? Go to which website?
harky
No website. The website is the IP address.
Just like you go in to your router.
HTTP://192....
Marple
Sineoji PT528V
I'm having issues connecting to my webcam from outside, my setup is using PT528v on wireless connection to Linksys Velop Tri-Band. Anyone could kindly help?
Hi can check you still using PT528v? So got any issues? I am using PT528v and now Dean has disappeared. :(
harky
it very hard to teach u de.. is not somthing tht can do teach u step by step..
all u need to do, is go in ur cam & router and explore the setting inside.
via the ip address.
if u cant access the IP cam... i think u need to do hard reset..
think u use IE, dont use chrome.
ur cam look like wanscam one, can follow this...
https://tutoriels.domotique-store.fr/images/WANSCAM/manuels/WANSCAM-JW-IPCAM-MANUAL-EN.pdf
the rest is on ur own.. no one can teach u because diff router config diff way.
need someone who has IT background to do it.
Marple
via the ip address.
Guess I have to change IP cam. No point wasting time for something I dont know. Any recommendations for similar type as Sineoji IP cam which I can mount on to the wall? Thanks
harky
most can... xiaomi 2k quite gd..
scan QR code to link ur mobile app to watch
