Wireless IP Camera thread
harky
orh their servers still active? lol
no. dont have to use their server.
U need to do some setting (port forwarding) on ur router.
and get ddns (cant remember if need a nt but u can get it free on No-IP)
thn do some setting on the cam inside when u login @ home via IP
if u use ASUA router, should be easy i think the ddns come with router so can easy port forwarding
the reason need to do port forwarding & ddns is because we cannot access our IP (router) from outside netwrok UNLESS is at home because it connect to same router (same network).
stupidog
i tried many different brands and models of ipcam man.
from vstarcam to xiaomi to focos to wyze.
for image / video quality , vstarcam better.
for less problematic app, wyze better
at first bought 3 ipcams + 3 android tablets, cos i use it to monitor my old folks at home.
then hell man, it's either the ipcams keep going offline or the app kept hanging for vstarcam and xiaomi.
vstarcam - one time just before my mother fell down, the room ipcam went offline knn.
if it didnt offline, i would have told my maid to catch up to her before she fell from bed.
knn so unreliable.
so i switch cams to xiaomi.
xiaomi cam it's ok, but the app is sucks. kept hanging n hanging at times. all 3 tablets are Samsung A7.
all also got issue. knn
made me dulan, bought Wyze and 3 x ipad pro refurbished from apple store.
From August until now , never reboot before also no d/c no hanging of the app.
so far so good for wyze ... money is not an issue when we can prevent accidents to happen.
networked
just bought 2x xiaomi 2k cams. so far so gd.
my home apps used to hang on the older model but for 2k its seems pretty stable.
keenklee
knn so unreliable.
You have to visually detect or the app have some sort of function e.g. blinking to indicate movement ?
Eggroe
Hi all,
I'm using sineoji 714 ipcam (recently took it out to use again).
I have a problem in getting my ipcam to connect to my WiFi. I recently changed my router to a 5G supported band and the ipcam autoconnects to that. I understand that the the cam only supports 2.4ghz and have a separate WiFi for 2.4Ghz band.
I've tried to go into settings (via app through LAN cable) to the 2.4ghz band but a message prompts saying "WiFi settings failed". Any advise on how to resolve this?
Separately, how do I hard reset the camera so it goes into configuration mode (with the beep beep beep) again?
Camera works via LAN cable BTW.
Thanks!
stupidog
Yes. When there is movement, the app will alert you ?
yes, recently i installed one at my doorstep cos my packages keep end up missing.
i set the motion detection just outside my gate.
anyone walk past my gate , the app will notify me and as well as capture a video clip.
only for the gate cam i sub the camplus annually. the rest using SD card to record.
kryptonitekillsu
hi guys need some help here.... anyone know currently which telco's sim card with data allows port forwarding for cctv....
my cctv for shop stopped working after my old sim card expired.... i replace with new one from circle line doesnt work then i realise new sim cards are using different ip or something that doesnt allow to work.... anyone have any idea abt this?
Apparatus
ARLO (by NETGEAR) security products (ip cameras, video doorbells, chimes etc) big sale at
https://kaira.arlostore.sg/
Anybody owns ARLO security products? Thinking of buying the bundles Ultra 2 cameras and Essential video doorbell with chime 2 leh
The products now are selling cheaper than at CHALLENGER and HN
Apparatus
Or can get the cheaper EUFY security products from TECH HOUSE and Amazon
FYI, TECH HOUSE in Singapore is the distributor of EUFY (by ANKER) products. The shops are mainly located in the shopping centres
TECH HOUSE don't carry all the EUFY security products. Those that are not available at TECH HOUSE can be purchased from Amazon
Apparatus
Just disposed off my old 1080p SAMSUNG ip cameras and my 1st Gen Ring video doorbell and upgrade using EUFY 2K security products instead. One app to rule them all.
EUFY 2K Battery Video Doorbell cw Homebase 2 review
There are many YT reviews on them. Check them out.
Some things you need to know if you want to use the battery-powered EUFY 2K video doorbell. Most video doorbells will have some of the below too.
1) Cloud storage requires subscription
2) Although battery-powered you can hard-wired it as well
3) Comes with full duplex 2-way audio
4) Doorbell is NOT theft-proof
5) All EUFY products which connect to the HomeBase 2 hub use its own proprietary WiFi
6) No distortion/warp correction i.e. have fisheye video effect
7) Expect to have some missed/delayed video footage/notifications due to location, ISP and internet traffic
Have been testing the combo these few days and below are the PROS and CONS
iu
PROS
1) S$329 for the bundle
2) 2K resolution (2560x1920)
3) Great privacy with no subscription required for local video storage. Videos can be stored locally and encrypted in HomeBase 2’s built-in 16GB eMMC inside the house. When memory is full it’ll override existing video footage
4) Very easy to set up for all Eufy products (I have the cheap EUFY 2K Indoor Cams as well but they cannot connect to the HomeBase 2 hub, only the router WiFi)
5) Connects directly to the provided HomeBase 2 hub and NOT directly to WiFi
6) Homebase 2 hub allows the connection of many Eufy cameras, chime, video doorbell, motion sensor, keypad etc.
7) Have notifications when doorbell is pressed and when motion is detected (to complement your outdoor cameras)
8) Homebase 2 connects to router using Ethernet or WiFi 2.4GHz. If use WiFi then HomeBase 2 can be located further from the router.
9) Homebase 2 has a chime and siren built-in
10) Can have add-on Eufy Chime 2 connected to the USB port on the Homebase 2
11) Stores 2K resolution video clips at 4:3 ratio in HomeBase 2 hub
12) Faster firmware updates
13) Use of USB-A charging cable allows extension of power supply cables with ease as compared to using barrel-pin connector charging cable/proprietary magnetic charging cable.
14) If internet is down, you cannot receive notifications nor view the video clips in HomeBase 2 local storage for they need to go through Eufy servers in the cloud. However, during the internet down video recording (through the internal proprietary WiFi between the Homebase 2 and the video doorbell/cameras) is still ongoing in the HomeBase 2 provided the AC power is still available or it has a backup battery. The notifications and the videos will show up once the internet has been restored.
15) Very slight delay (a few seconds) for notifications during motion detection (if it detects) and audio communication (less than a second) provided everything goes smoothly like favorable location, great 4G LTE signal strength etc
CONS
1) Cannot work if set VPN in router
2) Notify user when doorbell is pressed. No ringing of phone unlike Arlo.
3) No 3-sec pre-recorded (buffered) video footage
4) Picture won't be as great as Arlo for it comes with WDR and not HDR
5) 160 deg FOV. Arlo comes with 180 FOV
6) Video is 15fps unlike Arlo's 24fps
7) Additional chimes require purchase
8) No external memory expansion via USB for the Homebase 2
9) When user is answering the visitor, the doorbell will not auto record the visitor due to the PIR settings, the user can record the video himself. Although the doorbell supports 2-way audio but it records one way(on the camera side). Also, the audio in the recorded video is hardly audible and choppy.
10) Homebase 2 has no battery built in. Need to buy add-on battery pack or use a UPS as backup
11) No color night vision
12) Web portal(browser) allows viewing of one camera at any one time only
13) Unable to play encrypted recorded video clips in HomeBase 2 local storage from web portal(browser). Needs to pay cloud subscription for that. However, can only play in the tablet/phone’s app
14) Eufy is owned by ANKER which is a Chinese company. And Eufy apps are created by OCEANWING another Chinese company. Eufy sends out DNS queries to Google/China DNS security servers hosted on AWS, Singapore and Germany.
Note:- Motion detection is ineffective on 4G LTE. Getting very late or mostly no notifications at all. Motion detection notification is more effective on WiFi network. Using a 'Always-On' VPN on 4G LTE, setting to highest sensitivity and ā€˜Human’ detection help in getting faster notification.
jonleelk
Hi. Anyone has experience setting up a 4G LTE security camera that can work with local 4G SIM card, so that we can view the video from a mobile phone? Indoor location but no internet available.
