reborn
thanks for advice guys - i learnt alot last few days. in fact, i event made a trip down to Areit building (guess what - i forgot it was the original aztech building) down at Ubi to fix another product - my aztech homeplug (unconsciously becoming a fan).
What i found so far - very different from my 1st experience for the WIPC408HD IP cam product.
After testing it on my PC - i found the resolution and speed is very good. it can run 1280*720 at 4096 bitrate, at 30 fps without breaking a sweat.
i do find that the IR kicks in very early - its pretty bright here but once IR/ night vision kicks in - everything goes greyscale. no more color.
one plus point is the IP cam is a webserver. just point to the IP e.g. 192.168.1.100:8081 - you can start managing recording, resolution, audio, PTZ, multicam (wierdly it can.. remember this is the webserver of 1 camera, not a software i install on my pc), motion detection, etc.
the problem is - i had alot of trouble configuring - but since i met a new friend at Aztech support (very helpful guy) - he teamviewer into my PC and help set it up.
the limitations of the camera is as such -
many antivirus such as AVG and AVAST will interfere with connection between PC and IP CAM - they have to be disabled (till i find a way).
IE10 cannot be used with this IP CAM (in fact, chrome and mozila does not work too). you have to use IE9.0 (which comes with windows 7).
the above limitations might give you guys a little sour aftertaste and i apologize if i hurt aztech sales on this - but i believe future firmware patches for this very new product should fix it.
also, a friend noted that if you are doing recording - do note that IP Cam can suck up your bandwidth fast, killing your downloads/ video stream/ gaming/ etc - especially if you use several IP cams recording at once. also note that SD cards have read/write life.. which basically dont last that long - so buy many cheap ones rather than one expensive one (imo)
i think its a great hardware for $175 from simlim - and i believe software is coming to fix it - hence this is a keeper
thanks again for all - hope the above helps.
