tigerwoods
- Oct 7, 2005
You can choose the one with magnetic stick on one if you can't use the clip onThanks Tigerwoods, I'll buy one and see if it fits onto my T7837WIP.
They were my EX-COY IT Vendor, so it just happen that they started Distribution and brought in the IP Cameras. I was their volunteer product tester for the range of cameras they brought in cos I was hunting for an IP camera back then to monitor my kid n dog.
I had multiple D-Link, Linksys, Apexis cameras before, and gave away after I upgraded.
Started with Foscam FI8918W cam with them. Almost every 3 months I return the product to them cos of Motor issue. 1st time, motor stuck, 2nd time, motor no longer move. Take down camera, can hear something dropped off inside. 3rd time, again motor screwed up. I gave up. Then they offer to replace with H6837WI. I used VStarcam and did not have problem for 6 months on the motor. H6837WIP came and I upgraded cos I was impressed with the LIVE Streaming which now all the major brands are only just started. When I step into the T series, it was a whole total new experience. The main factory NEVER wanted audio with recording. It was MARIX that pushed the factory hard for it knowing the market well, so T series users should see an update soon in late September or early October. In fact, yes, VStarcam products are never perfect, its the distributors that listen to our problem that makes the manufacturer resolve the issue or enhance it. It makes a big difference.
That's why I strongly recommends them to anyone. A good company should be kept alive and not die off the market cos of unhealthy price competition.
Now I really look forward to see the sample test unit of the 3x outdoor camera. I will write a review for it too.
Not all are fisheye, some are wide angle both are different. Choose the right one for your cam.haha good idea
this fisheye lens is for phone actually
Its preset function for camera #2 onwards. v3.15 will crash when preset camera #2 onwards. v3.16 is able to set 2 preset positions for camera #2 and #3 but crash on 3rd.
I organised a group buy and Marix is very helpful to assist my friends to setup mutiple cameras.
Thanks for the disclosure![]()
Dun worry, u r not the only one tat asked about this. To me a good distributor for product means that they acknowledge product limitations n problem.
but here hard to get reply when a new comer requesting for help :XHere here! I always appreciate content experts who provide factual reviews...the good and the bad. Always look forward to Dr_ARCher and urself in providing ur opinions/reviews.
It is not hard to get a reply. The reply is already there in the thread. All of us are newbie ones, and we all learn along the way. If you look at this thread, there are a wealth of information on the brands, the models, the features, the set-ups etc. Why don't you do a search and look at some old posts?
Sometimes, we hesitate to recommend a brand/model to every newcomer, not because we don't want to, but because we may be deemed to be biased/fanboy/paid etc.
You asked for a wireless IP camera that does not need internet connection. By definition, a wireless IP camera is a camera that works wirelessly (hence the wireless term) and within a network (hence the term IP, which means internet protocol). So I doubt if you will find a wireless IP camera that does not require an internet connection.
What you need is therefore a camera that does not need an internet router. Without defining what is affordable (affordable means different prices to different people), it is also difficult to suggest anything.
Now, if you search around (either Google or the threads here), you will find that there is only one particular model that operates without an internet: the Prolink PHC105:
PROLiNK - Challenge The Limit
Presumably, this camera requires you to insert a SIM card, and it operates like a 3G telephone. I have never used it before, so I cannot tell you how good it is. There is a short write-up on this Hardwarezone site, so you might want to check that you.
Thanks a lot, sorry for my foolish request, I got a question here though.. I'm planning to get a d link 942l ip camera, I noticed there a micro so slot there I wonder if it will record by itself and save it inside the memory card
I am not sure what you mean by 'record by itself'. Some cameras allow you to set recording upon motion detection (to save you the space). For some, you activate it via a on-off button. For others, you can set up a time to start recording.
Now just realize that everything can be set~~
i'm really a retard nowO_O sorry i think i mistakenly thought it normally recorded and upload to the cloud storage,Now just realize that everything can be set~~
Hi,
I am interested in the Vstarcam T7837WIP. I checked out the Marix website but I have some further questions that I hope can be answered.
I understand that it can record to a SD card:
- Does it record both audio and video?
- Is the video in colour?
- How many hours of recording can a 32GB card contain on normal resolution?
For Android viewing:
- Does the app support playback of SD-card recorded videos?
- Is the SD-Card recording playback continuous, or split into multiple files?
General questions:
- How long is the power cable without the 3m extension?
- Can I mount it to the wall using 3m double sided tapes? Has anyone tried?
- Is there a light on the camera when it's recording? Can the light be removed?
How does it compare against D-Link DCS-942L and Foscam FI9821W?
In terms of
- SD-card recording
- NAS recording
- Live playback
- SD card recording playback
- mounting options
Apologies for the long list of questions.
Thanks!
