Dear geckoSG,
apologies, our technician gave you the wrong details of your purchase from us base on faded PI from factory. The EasyN models that you had purchased from us 2 years back during the pre-order were;
FS-611B-M176I &
HS-691B-M186I.
These were the comparison models from EasyN to us for product comparison against F6836W & H6837WI.
Tech specs as requested as follows;
FS-611B-M176I
CPU Operation system:Embedded Linux OS
Microcomputer processor:
32Bit ARM9 RISC core
•Compression format':
G.711/G.726 built-in two-way audio processor, support sound monitor
•Audio Gain:AGC
•Compression format:MJPEG
•Signal system:CMOS 300,000 pixel
•Frame rate:
30fps
Resolution:VGA(640*480),QVGA(320*240) QQVGA(160*120)
•Image adjustment:Brightness, contrast, chroma, saturation.
•Free domain name bounded
•Support 10 visitors at the same time
H.264 compression format
•Built-in IR-CUT, auto-switch day and night
•Wi-Fi compliant with wireless standards IEEE 802.11b/g/n
•Mobile view,Support most of the intelligent cellphone(such as Iphone,Android,Windows mobile)
Pan:270° ,Tilt: 90°
IR night vision 15m
With 32G SD card slot
•Network interface:RJ-45 10/100M self-adaptable Ethernet slot
•Protocol:TCP/IP,HTTP,TCP,ICMP,UDP,ARP, IGMP,SMTP,FTP,DHCP,DNS,DDNS,NTP,UPNP,RTSP etc
•Wireless:WIFI,802.11 b/g
•Online visitor:Support 15 visitors at the same time
•IP mode: Dynamic IP address, static IP address, PPPOE
HS-691B-M186I
32Bit RSIC Embedded Processor
G.726/G.711
•Input: one channel linear input /mircrophone input
•Output: Audio output
H.264 main profile level 3,dual stream
•Signal system
AL or NTSC
•Frame rate:
25fps
•Resolution:
•Minimum illumination:0.3 Lux/F1.2
•S/N ratio:48DB
•WB, BLC:Auto
•Lens:Standard: 3.6mm
•Pan Tilt Function: Pan:270° ,Tilt: 90°
•H.264 compression format
•IR night vision 15m
•With 32G SD card slot
•Network interface:10Base-T/100Base-TX Ethernet slot
•Online visitor:Support 10 visitors at the same time
