Hi geckoSG,
Can you explain what you mean by PIC1007WIP viewing angle setback compared to Vstarcam T7833WIP? I searched up on vstarcam's viewing angle and it says 4~9mm@F1.4/51~24˚. Im sorry I can't understand what that means, can you or anyone on this forum help to explain? Is it that - at the most zoomed out setting, the left to right viewing angle is 51 degree?
Software wise,
Can both monitor from andriod phone and ipad?
Can both access the recorded footage in their microsd cards wirelessly from andriod and ipad?
Is the recording done 24/7 or only when they detect motion?
And which software is more user friendly? Especially for aunties to use......
Thanks lots !!
OK, I'll only share what I've had hands-on here. The T7833WIP is an outdoor camera, the lens information you see is saying that if you zoom out, it will show the image with 4mm lens, and zoomed in, it will show using 9mm lens. Something like tat. It is a 3 X Optical zoom camera, concept similar to DSLR cameras. The camera can pan (left/right) angle up to 355 degree. Tilt (up/down) is 90 degree.
The ProLink camera, why I state here as setback in viewing is. If you look at the design, it cannot view anything behind it, its just like the Linksys WVC 200 which I used to have, I can only view front and limited sideways. Viewing angle will be much limited, but what I like about the camera is that it comes with hardware PIR motion detector, this is important and useful for motion detection. The hardware improves the accuracy of the motion detection which most IP Cameras does comparison using software which T7833WIP is doing.
I know VStarcam certainly can use iOS and Android mobiles & tablets. Can record to MicroSD Card. Can playback via mobile, BUT it does not allow you to play at certain time of the clip. U need to watch the WHOLE CLIP. No AUDIO recording for now as well. It can be motion detect recording or continuous recording.
Prolink have their own mobile APP as well and they should be able to record to MicroSD Card too and similar motion or continuous recording. I've not tested it myself, so can't comment much about it. So, Pro-Link users who owns the model could help to share your experience as well.
Or before you buy, go down FUNAN Challenger. Take a look at the display demos there before you commit to buy, there's D-Link, Pro-Link, Aztech, Sineoji, VStarcam, etc. Always do comparison first of any products before you buy. So you will not regret yourself.
Information here are shared by vendors, end-users, so you do your own homework with read ups here, view the reviews that people do online, test out any demos that are release to the public and then decide which model meets your need.
Not everyone shares the same view for the same product. Hope this helps.
