Wireless vs Wired Charging (Samsung)
Teo Ming Ern
There are converter adapter bundled in the Note8 package (micro-usb to c, usb to c). You can use those converter adapter.
Oh yes thanks!
By the way, other than the connector difference, is there a difference in charging speed?
tkl23786
Oh yes thanks!
All Samsung fast charge charger have output of 9V, 1.67A or 5V, 2A
I checked with the charger that came with my Note 5 and Note8. Both have the same output.
As long as the cable can carry 9V, 1.67A of electricity, the charging speed should not differ much unless the battery itself kaput.
Teo Ming Ern
I'm asking about wireless charging... if the charging pad got difference or not...
Jurong640
if you got the S7 series and above wireless charging pad, it's all fast charge.
Those wireless charging with no 45 degree angle, are normal wireless charging, no fast wireless
Teo Ming Ern
Oh I see... that's great! Don't need to buy another one... I think I'll recontract...
Lucky123
Mine the flat table type but got fast wireless leh.
Charlie_Zhan
hopefully not 5 years, probably minimum 2 years, next device should be Note 10. The 10th edition of Note series should be a big bang.
windows skipped 9 and went straight from 8 to 10.. iphone skipped 9 and went straight from 8 to 10..
maybe samsung would do the same as well? :s13:
i have both the flat and standing wireless charging pads from samsung and all of them are fast charging pads.. :D
Jurong640
Samsung done it before and it went BIANG. From Note 5 to Note7.
royfrosty
As long as there is heat, battery will degrade over time, be it fast charging wired or wireless charging.
The fact that charging at 9v 1.67A it is hot. 15w worth of output power is definitely hotter than wireless which is outputing a total of 2A 5V, 10W of output power.
But wireless charging takes a longer time to charge your phone. Which as a result may heat up the phone for a longer period of time.
But either way, before the battery dies, the phone is due to change.
Jurong640
So in that case, neither is better. Just charge the way as per normal.
Arandalo
On Samsung phones there's the option to disable fast wired charging as as well as fast wireless charging. So personally I would disable fast option for most of the time whether wired or wireless charging, and turn on the fast option if I need an urgent charge.
