Won Exchange Rate
registeredname
Today rate highest 834.20..
I going end of this month, wanna change $800, waiting for 835 i whack liao :s13:
How much you going to change? $800?
The difference is only 640 won, which is about 85 cents?
For 2k SGD, the difference between 834.20 and 835 is only around KRW1,600 which is about $2. Why waste your time checking everyday just to hit 835? You're not shorting forex for a living, I'm sure your effort of checking and checking is worth more than $2 right? Or 85 cents for your case. Just change and get it out of your mind :s13:
What if it drops...below 830 just because you're waiting to save that 85 cents? :s22:
Just my 2c (smaller than 85cents) so take it with a pinch of salt =:p
grasscut
the rate now dropped so much. anyone know if myeongdong rate is better than sg ones now?
claudiusje
just came back from myeongdong. last saw it at 823. i looked at them a few times. their rates were never better than raffles arcade rates.
shadow84
Better off changing to USD and then to KRW? Seems like i get a slightly better rate as compared to changing to KRW directly.
