Wear thicker socks. Or switch from cotton to wool dress socks.
Need to change my soft soft and thin socks..
Hi all,
would like to have good advise or maybe where can I find small size office shoes
I have a really small feet.
maybe EUR 35 - 36
I know there are customize and bespoke shoes. but it would cost a lot for my budget. I need office wear shoe for my daily work only. hoping to get 200-300 or below.
Thanks
wow, 35-36 is UK size 1-2 leh. I don't think any shop got carry so small shoes ba.
Combination of tongue pads and insoles will help. I'm not aware if any local cobblers have tongue pads in stock though. I'm interested to know as well if there are.
My shoe tree from taobao arrived. Ordered size 40 for my Loake UK 7 but the shoe tree seems to run big and it cant fit the whole thing in. Sigh. Anyone wanna take over from me?
Eh should be ok one leh. I order 43 and fit my uk9 carmina.. Very snug fit, need to use a lot strength to push in.. But it will fit.
Seems more than anything that you got wrong size. Not saying it's your fault.. Just that the seller might have done poor qc on his goods.But if u need alot of strength to oush in means it will stretch the shoe. Will it spoil the shoe?
I don't think will stretch the shoe la, but I'm no expert. Once I pushed it in the shoe become very structured and the creasings at the vamp is gone. I think because those good box calf is very firm, it should be hard to push in.
If yours really can't push in at all, I think the qc wrong ba, as darth mentioned.. I think taobao got put the length of the shoe tree in the description, you might want to double check and see whether it's the correct one.
Both pairs also cannot fit? Dont force it in, it should fit snug but fine. The seller has a size dimensions chart, better double check to find out the real size. Daigou now got free agent fee, too bad u missed it or returns would be much easier lol
My wife managed to forced it in for me but super tight. I think its because the front part of the shoe tree is too big, length wise is ok
My wife managed to forced it in for me but super tight. is too big, length wise is ok
Some would say this is a good problem to have.
LOL. Now when i re-read my own comments, i find it funny
Btw i tried the tree on another shoe and not as tight.
I tihnk the last of my Loake shoes may be abit smaller. BUt I hope the shoe tree will not stretch and spoil my shoes
