Renomat is very powerful. You have to use it sparingly. Which is the patch that showed up after you used Renomat?
Which is the area that that holds the dark colour cream?
Did you just do this? Was it done consecutively?
Near the edges broque border of the toe caps towards the uppers. You can also see left toe cap dark circle. Actually most of the base dye has come off.
Looks like same as my Edetal.
Instead of using cloth to polish, i use my hand to apply wax(very thick layer) and use brush to brush until it melt into the pores. Then I leave it overnight to let me dry.
After that I just polish like normal.
The reason why I never use cloth to polish wax is wax, cause I felt that I am removing the polish rather than building it up
I used cloth to polish off. Then the toe caps turned white I think from oxidation. I thought it was wax and rubbed a bit more. Then realised it was the base dye.
