- Sep 17, 2011
anyone buy meermin can pm me also can share shipping...
Yes I was talking about the brands like meermin Ed or even like G&G, compared to those mass market brand like aldo.
The high end brand always seem to look very good but haven't seen much pictures where they've been worn long and hard. I know they can be resoled and last for a long time, just wondering how the leather uppers hold up with time.
Thanks for taking the time to share the info!
If taken care properly the uppers can last at least a decade. I have resoled vintage shoes and the upper is still holding up well. Even the abused shoes can be revitalised and renewed with a bit of TLC.
What do you guys think of this handmade shoes made in Indonesia? Priced at 150SGD.
I think when one needs to distinguish between hand and machine welt, whatever gets the mag across is crucial. Im trying to explain that it is still done by hand on pricier shoes.
How much abuse are we talkinghere? Scratches all over? Plus water damage due to rain and mud?
Bro, where in SG can resole GY weld shoe?
just wanted to give my 2 cents on this matter & more but could only find the time to now,
you are right in that most arguments (and believe me it's a perennial issue) of this sort are mainly over semantics, so I shall not go into that. but i think it is a mistake to automatically assume that more $$$ = hand welted = better.
basically more $$$ usually = more manual labour = more artisanal value, but as you know that does not automatically make the shoe better. even "hand welted" shoes are made with some degree of machine assistance as obviously a machine is more accurate than a human.
when you pay top dollar, imo you should consider the looks, comfort and quality first, especially material and construction quality. there are good blakes and there are awful goodyears.
to everyone else, what do you want out of the shoe?
if you want elegance, may I suggest blake or blake-rapid with optional patina finishings, as they have (imo) a much better profile than a GY or norwegian. just remember to stay out of water especially in sg as organic materials can degrade due to moisture. and treat the shoe carefully.
if you want durability then look into GY or norwegian. All good shoes can be resoled but GY is obviously easier to find in terms of people who will do it. just remember these shoes are bulkier, heavier, and not very flexible.
if you want comfort/fit then please consider MTO/bespoke depending on your budget. but also carefully consider your style and material options, it seems funny to have a MTO made out of bookbinder...
when i say good quality what i mean is that the uppers are full grain, the soles (stitching/welting) are channeled and better still masked, the insole is thick leather and the welt is directly attached to flaps cut from the insole. of course the best and easiest way make sure of these things IMO is through word of mouth about the reputation of the shoemaker.
I have no experience at all with EdatAl so no comments here but DW's $600 "goodyear welted" shoes don't even have a channeled sole last time i checked for some models. And a badly channeled sole for the more expensive ones. Which is really dumb since the stitching is vulnerable to water and wear.
anyway like i said some time back a loake 1880 or barker from robinsons sale should be good enough for almost everyone except serious shoe enthusiasts, and with an affordable price tag too.![]()
Common mistakes:
Daily wear esp without socks
Not using shoe tree
Not using shoe horn
Not drying properly when wet
Not regularly maintained
Allowing dirt to accumulate
All the above will shorten the life span of the shoe. As long as it is not salt water, mud and rain is not an issue to properly treated shoes.
I am guilt of not using shoe horn. Lol
Maybe I should think if getting those long ones
That's quite impt tbh, and helps saves time too. If you have to force your feet into the shoes, and use your finger to try and slip your feet in, chances are you'll damage the back part after some time
If I were you, I'd get a longer one. Don't have to bend all the way down.
Here's my shoe-kit with horn:
Need to find out how much time saved. Lol
Not using finger technique but I sure love your wooden box. I just want something to hold on the shoe so that I can polish Ian's buff it easy. Anything to recommend
