Working Shoe for Young Exec
Buy clothes or some other stuff with the voucher. Loakes are easily about a hundred dollars cheaper online at a place like Pediwear.
Thanks for the advice!
OT a bit: got any recommendations for working clothes? Previously got my shirts from G2000, then tried out tailor but not good experience...
jonleelk
U can try Raoul, but buy only during their twice a year sale with min 30% discount.
Ind1go
Looking to sell the following shoes.
Paid $300 for the shoe, looking to sell at $250, worn twice.
Comes with 2 tins of shoe polish, shoe horn, shoe trees and box
Brand : Herring Shoes (Made by Loakes)
Model & Color : Richmond - Dark Brown Calf
Sole : Goodyear Welted Leather (with Topy)
Heel : 1/4 Rubber, 3/4 Leather
Size : UK9.5G, US10.5W (Wide)
I'm selling these shoes because I bought a size too small for my feet. Should have gotten my feet measured before.. My loss, your gain.
The Dark Brown calf goes well with gray trousers and it is full grain leather (not the polished stuff that you get from Aldo, Rockport etc.)
Got the Topy applied by Mirrco at $22, to make the leather sole last longer and to get rid of the slippery feeling of leather.
Interested? Drop me a PM and let's discuss.
LiquidShaDow
Robinsons has some brands which are decent. Unless you're looking for premium fabrics and very nice fit. Cost of the shirts determine the quality there, so I would recommend those that cost around $80 and up after any sale discounts. Those are generally one up from G2k if you're looking for office wear.
Ind1go
I was at Marks and Spencer, Wheelock Place, and they have packs of 2 shirts for $79. Quality wise is better than G2K. Also have pants for $49. Decent deal.
Finding a good tailor is a bit of a hit or miss. I realise that the tailor may make your first 'test' shirt very well, but subsequent shirts are quite lousy.
Find a OTR that fits you well with minimal alteration required. Or look for a better tailor. The hwz thread on tailors seems like a good start.
Back on topic : Anyone seen any shops selling Shell cordovan shoes?
WonderGirl
Herring shoes UK sold out on most Church's shoes on common sizes. Anymore URLs for Church's to recommend?
Ind1go
I got some excess bottles of Saphir Renovateur that I want to let go.
Drop me a PM if you are interested.
shadow99er
I bought a pair of black Loake from Robinsons last month for $199. I wish to buy another pair but its quite expensive in Robinsons, going for about $350. I wish to buy another pair online but where can I obtain those promotion codes that can entitle me to freebies eg shoetrees??
huangwn88
Hey guys, will using a shoe tree really prevent from creases from forming on shoe? I thought creases will be formed the moment you walk with the shoe?
Ind1go
Unless you walk like a penguin, there is no real way to avoid creasing the shoes.
However, a shoe tree helps in 2 ways.
1) Lessens the creases by keeping the shoe in shape, while not being worn.
2) Wooden shoe trees absorb the moisture from your shoe. This helps to prevent odors. Also helps the leather last longer. Leather doesn't like to be moist and damp.
Plastic shoe trees help to keep the shape, but don't have any moisture absorbing ability. It works in a pinch, but I wouldn't use it as a long term solution.
Also keeping the shoes well cared for, with creams and conditioners, will go a long way in keeping deep creases from setting.
Unless the pair of shoes have polished leather uppers, which will have deep creases regardless.
Most people recommend two shoes for rotation, so that one pair can completely rest while the shoe tree does its work.
huangwn88
Thanks for the reply :). Do you know how do take care of nubuck leather shoes?
doody_
What kind of brands are good for working shoes? I have a pair from Hush Puppies but it's pretty old so looking to get at least 2 new pairs. They need to be comfortable, can last for at least a year and cost around $150.
Going off-topic but does anyone also know where I can get loafers/slip-ons? I had a pair from Pedro but like someone mentioned earlier, the quality is really lousy and I have to get a new one.
Ind1go
Suede and Nubuck shoes still require shoe trees, just for getting rid of the moisture from daily wear.
Suede and Nubuck care is a bit more complicated as you can't use a wax or polish to just hide away stains. I think in the case of nubuck, prevention is extremely important with a good water / stain repellent. Water isn't a major issue because it dries up without any stain, but oil and alcohol will discolour your shoe.
Also good to have is a suede eraser, which lets you rub out the stains easily.
Probably the basic brush + eraser combo from shoe stores will be sufficient for normal care.
You can also wash your shoe in fact, Leffot Presents - This Is The Way We Wash Our Suede - YouTube , but I have never tried it.
huangwn88
But can I put conditioner on it? Mine is actually a pair of rm williams chukka. The store guy say can put some conditioner. But I read online that shouldn't apply anything on nubuck.
Ind1go
Apparently, there is a Suede / Nubuck Conditioner by Ecco available. I've never used it.
My routine for Suede is
1) Brush to remove dirt
2) Suede Eraser to get rid of stains and cleaner if really dirty
3) Damp cloth to wipe everything down
4) Brush again to raise nap of suede
5) Waterproofing spray
