thundermarch
- Dec 5, 2013
I might be getting a pair of burnished captoe antique brown monks from edetal tonight.
sounds good brother
remember to post pics!
U burnished the captoe on your own? Don't recall the retail model looking like that.
U mean stretch the sides? Technically your toes would never reach the captoe area (then the size would be wrong). Captoe itself would have stiffener and i think the shape quite fixed?
Where to get stretching done? Also interested (for sides not captoe though)
haha
thats true
indeed the model numbers tally
i didnt even notice the discrepancy in the number of eyelets
but i dont matter to me
i was too taken in by how good it looked
Hi,
I'm selling the above pair of shoes which was was bought for me from the UK but unfortunately doesn't fit. It's a great looker, and perfect for work or any special occasions!
No box as there was no space for it in the suitcase, but comes with the cloth that was in the box.
Text me at 9687O31zero if interested.
Thanks!
A question on polishing
When applying cream / wax to shoes in more unusual colors
eg . burgundy , museum calf, different shades of brown, burnished areas , how do you choose what color cream / wax to use?
saphir has many choices, but i notice they dont have burgundy wax (they only have mahogany / bordeaux) . also i think the shades of brown may not be a perfect match
in general, is it a good idea to use neutral creams? and neutral waxes?
Nice shoes bro!
Can i check , when you guys post pictures on HWZ, are you also prompted to "insert url" in the box, as in, cannot directly attach the picture?
Nice! $349? Question: u have various matching belts for your brown shoes?
Nice shoes bro!
Bordeaux = burgundy
Neutral tends to leave white streaks where creases form. I don't use neutral cream, but I use old, dry Collonil 1909 neutral wax in very tiny amounts as something like a "top coat", or sometimes I mix it in a little bit with the final layer of whichever colour wax I'm using. I like to mix different brands of polish, I don't know why but I find it easier to get a good shine that way.
When it comes to antiqued or burnished calf, don't sweat the details. Use a lighter shade of polish if you're afraid of the leather becoming darker. Leather is skin, so like it or not it'll never look the same months later no matter how you maintain it. Build up the wax slowly in thin layers, then use a darker wax for burnished areas if you want to.
I'd go into greater detail but there's better information available online.
I think if u are really particular to keep a unique shade then should use neutral or just reno to maintain the leather.
Not that creme or wax will change the colour. But if u fancy a mirror shine, cannot avoid wax. I personally find its ok to use colour wax/creme, colour wont change drastically n u can always give a good clean to strip off the colour.
thanks for the information; learn so much about shoe care from this thread!
