Working Shoe for Young Exec
MasonAndSmith
I think if u are really particular to keep a unique shade then should use neutral or just reno to maintain the leather.
Not that creme or wax will change the colour. But if u fancy a mirror shine, cannot avoid wax. I personally find its ok to use colour wax/creme, colour wont change drastically n u can always give a good clean to strip off the colour.
I wouldn't reccomend using the renovateur cream too often though; once in a while to remove the previous layers of polish is fine. As for the colour of the creams and wax there will never be a product that matches the shoe colour completely (unless its your lucky day), you will be as safe as long as the products are used minimally
All in a Day
Hmm i thought renovateur (not renomat) is ok as a leather cleaner/moisturiser, no? What adverse effects could u share w us? Thanks!
Daniel.Y
For leather shoes, do you guys use the normal kiwi brush for polishing/buffing, or do you guys insist on horse/boar hair brushes? Thinking of getting one
All in a Day
I find both are ok. Horse hair bristles are indeed softer n therefore 'hurt' your leather less, if a dead cow's skin has feelings.
thundermarch
I'm hoping to get some opinions.
Bro BallGag did comment earlier that monks fit a little looser than oxfords.
I find the simpson size 9 in single Monks a pretty good fit. Snug but not tight or uncomfortable in any way. No heel slip whatsoever as well.
Should i opt for an oxford in simpson, would u think 9 would still be the size to go for?
BallGag
Yeah stick to the same size it should be fine. I usually only size down for loafers.
MasonAndSmith
Not exactly adverse per say; i was speaking to the teamfrom Saphir and their suggestion was also not to use the renovateur too often because of its characteristics (to strip and remove previous layers of polish ) so it can be quite be harsh on the leather surface if used too often. but of course i agree it does a great job as a cleaner!
Daniel.Y
Anyone can advise where could I get abbeyhorn products in singapore? Thinking of getting their shoe horns. Will there be any shipping restrictions if I were to buy them online and shop them to singapore?
All in a Day
Wow, upscale shoe horns. Dont see why there should be restrictions?
nippp0n
In our How to Shine a New Pair of Shoes tutorial, we recommend three steps:
Conditioning the leather using Saphir Renovateur
Polishing the entire shoe using a pigmented Saphir Cream Polish.
Use a Saphir Wax Polish to produce a high-gloss shine on the toe box.
How to Shine a New Pair of Shoes. The previous comments said that renovateur is a bit harsh on the leather so i'm wondering if any seniors here can share some tips on maintaining a black dress shoe?
Looking to invest in some basic shoe care products to maintain my shoe. :)
ChevyImpala
Just pulled the trigger on the Allen Edmonds Dalton Wingtip Dress Boots.
Where can I get decent shoe trees in Singapore? How much would it cost?
All in a Day
Congrats on getting the dress boots, pretty quick decision I must say. Curious how u plan to incorporate them into your dress wear? Am hesitant mainly becos I am not sure how the break of my pants would be with boots, and am not ready to tailor pants specially to go with dress boots at this point in time (or ever).
On the shoe tress, hope u've already PM-ed one of the guys here (see a few posts earlier) and found what you need.
Do share pics of the shoes when they arrived! cheers
All in a Day
Likewise, the literature I gathered from the internet seems to suggest that the renovateur is a pretty good calf leather conditioner for regular use (couple of times a month or so), even if you use no other shoe care product. I used it sparingly on my wife's old hand bag and I thought it worked pretty well too in cleaning the leather and giving it some suppleness.
Mason's comments (bearing in mind that he is a shoe care professional) has gotten me abit apprehensive now. Anyone like to chime in a 2nd opinion?
benz1987
Hi Seniors,
Can I check how different are the fittings G and F? I understand G is more of a wide fitting while F is of a medium fitting.
Let say my usual dress shoes are of UK 7 G and I am intending to get a shoe of "F" fitting. Do you all suggest the same UK 7 F or I should be looking at half a size up i.e UK 7.5 F
Thanks!
