Working Shoe for Young Exec
All in a Day
anyone can recommend shoe brands that have a relative thicker sole for better cushioning?
Firstly, depends on your shoe type preference. If cushioning is overriding priority, go for the 'comfort' dress shoe brands like geox, rockport, clarkes, ecco or even hush puppies.
If you're into welted european-type shoes (which forms a majority of the discussion here), then I would suggest simply getting your own insole inserts. You have to consider whether u have a high instep and your choice style of shoes. For e.g. High instep + oxford, you may not be able to fit the shoes with inserts.
Good luck!
kingcarlos
Good luck!
Thanks for the reply!. More interested in the oxfords etc. But yea, I do have high instep, so inserts probably will be an issue, esp with oxfords getting flatter at the front area.
cakes.cakes
Vibram sole avg $25. Most cobblers like Solemann should have. If Topy I think Shukey has.
Renovateur locally cheapest I found is on Carousell ($25). There is Pate de lux and Cream also ($28). Or else you can head down to Mason & Smith or EEA, they have.
Brush just go Mustafa lol
hi thanks for the info.
anyws i just bought a double monk shoe in ed et al.
i was wondering if anyone knows i shld vibram sole as a whole or just the tip or heel of shoe? or just the tip of shoe will do.
thundermarch
Good luck!
Brother man, you certainly give some of the best advice on this forum
kenzio8
Personal preference i suppose, but i did the front half for mine.
arcfire
The heel is already rubber so you can change when it wears out. It's a matter of preference whether you like the feeling of walking with leather sole or not. When the rubber is applied on the sole it will cover the front half of the sole. I haven't seen shoes with anything shorter though...
likehotbutter
you can try putting a tap like below, but a topy is normally good enough. Or topy + tap if your gait really wears out the front severely.
thundermarch
I'm so sorry. I cannot recall exactly who and I'm a little lazy to look
But approx 10 days ago someone asked me about how new rey fits relative to simpson
I only just received them today
my verdict is this
sizing up half is sufficient for me at least
compared to the simpson, new rey has a slightly narrower toe box but a more generous waist and also a slightly lower instep
its a pretty comfortable fit for me actually
cakes.cakes
will hearthache when put so many holes into the shoe :(
anyw anyone got idea where to get nice long socks for men?
starsandstripes
my verdict is this
NPNT!
How does the LM range compare with Carminas?
thundermarch
NPNT!
Was actually a bit lazy to post pics but since you asked I'll do so.
Anyway as a comparison you certainly can tell there is a difference between their LM and classic line. The leathers aren't great still. You can actually see from the pictures there is a fair bit of pulling / wrinkling.
My right medallion is also noticeably off centre. I'm not complaining since the shoes cost €210 ish.
Now, here's the thing. If you'd ask me, i'd still put my money on Carmina and spend another €70 or so. But that's me. I love Carminas. You might be asking someone who's biased. But objectively speaking, i still feel Carmina's leathers and finishing are better.
Then there's the issue of Meermin LMs being handwelted. The general consensus is that handwelted shoes are better. I haven't worn them long enough so i can't really comment. My other pair of LMs ... Don't feel much different from a GY welt to me.
Anyway, I'm sure you will make a good choice. Both are decent shoes. It's really a matter of preference and how you want to spend your money. Buy them, wear them, love them.
Oh yes. The shoes look pretty dark here but they're actually supposed to be Burgundy. Part of the reason is lighting. And part of it is the shade of Burgundy is really pretty dark.
20141211_204247_zpslbmpfltf.jpg~320x480
liquidy
Any decent pair of loafers (preferably Goodyear welt) you guys recommend, to be worn with berms?
thundermarch
Here's a better view so you can have a better idea of the last shape.
You can see the waist seems more roomy and there is more taper at the toe box. If you think you have a wider toe box, this may not be the last for you
20141211_171233_zpstut0uozu.jpg~320x480
arcfire
my verdict is this
Thanks bro! I'm still more keen on the Carmina. Unfortunately they don't have stock for the model that I'm keen on. Guess it'll have to wait. Saves my wallet for the moment.
starsandstripes
Carmina Simpson last looks better to me, unfortunately its not that popular everywhere. Its mostly rain and inca.
Simpson and uetam(loafers) are probably the best fit for me among the few lasts from Carmina (and brands) that i've tried. (inca, rain, simpson, uetam)
