Xiaomi Box Android TV Box
jim123
1. on Tv , it is better than starhub SD channels, slightly worse than hd channels.
Hi Gregory,
I've install 光芒体育 and the football stream for 光芒体育 is quite pixelated and i find it worse than SD. Do I need to do any setting on the app itself? Am using a 4k tv btw and have set the mibox video resolution to 3840X2160.
ironut
Nice. Looks like the cheapest Mi Box 3 around? (Other than buying from taobao)
ZynoXII
2. It has one USB and one OTG port, so it may not be necessary to get OTG cable. Just plug thumbdrive in USB port
thank you for your quick response :)
Hi Gregory,
this is contradicting though. :s22::s22::s13:
anyone knows when the rakuten discount ends? today?
ironut
!5% discount still got some time.
extra 5% mastercard discount is only every tuesday.
ZynoXII
Just bought from rakuten, the seller increased price to $95, instead of the $92.20.
used mastercard discount and MORETHANUSUAL, $76.71.
let's hope this product will not disappoint. :)
EDIT: went to check again, price rised to $99.
jace88
as long ur mibox is in the same network as ur dlna server, should not be a problem connecting. but the performance during streaming will depends on ur wifi liao.
Do you know if it will work out of the box or do I need to download other software? I can't read or understand Chinese hence I'm a little worried I will end up with a device I can't use.
I am assuming tv box performance will be better than my pioneer blu ray player which streams over wifi. It's not the wifi quality but rather some of my larger 1080p content stutters and skips frames.
yhw22
But now it given 5x points. :s13:
if using happypanda coupon still pay $79.90. Consider cheaper than Qoo10.
sjchai75
Hi all,
thinking of buying 1 xiaomi tv box 3, may I know which is the best broadband to use it? I am having starhub cable 100mb now. Is it good enough?
chinabluez
Hi. I have a problem. I accidentally click on 4k resolution on my mibox pro and now i am getting "video not supported" on my full hd tv. How can I reset the display resolution? I don't have a 4k tv.
asriznet
Err usually the resolution will revert to previous unless you accept the change. I'm guessing you accidentally accepted the change as well?
You can try entering recovery mode by switching off the mi box and back on again while pressing down home & option button.
kenboiboi
Hi Gregory,
I find that 光芒体育 doesnt work well on TV. Soccer matches appear to have ghosting effect and frame drops when the action becomes intense. I am not sure but it may be due to my TV? But I dont have any issues with other movies or shows. I tend to watch sports using other live tv apps or xbmc as they are smooth.
