Ya rakuten, stated as Dhl also but toll came. Ordered on 10th night time
Same too, still waiting for mine to arrive.
Just checked from toll and is out for delivery 9.21am. I kept search DHL but no find.
mibox can run view streams in kodi with hardware acceleration turned on?i also thought so. But I think it depends on your needs. Mine is a original stock firmware box. For now, I installed Kodi, HDPTV, Togic, and Shafa (actually I will rarely use shafa I think), and I feel more than enough for me. Since I seldom watch streaming, the original xiaomi player and Kodi are sufficient. HDPTV and Togic are just for me to try out.
As of now, no rooting nothing for me to do.
Maybe, I need to find stream source to watch live football on Kodi or other app.
Code not working anymorefor those who wants to buy stock mi box 3, can try rakuten.
just checkout with coupon code MORETHANUSUAL. I just bought my 3rd set.![]()
Code not working anymore![]()
Code works, thanks!try "happypanda"
Any guide for rooting so that hardware acceleration can be enabled? Thanks..stock firmware cannot, must be rooted then can hardware acceleration.
im using software acceleration, OK for my usage for now, so I did not root yet.
What's you mibox firmware version by the way? Seems like it's only supported up to 1.3.50 for the root to worki think u can find it in this thread itself. do a search for keyword like "root"
So far the root kit provided from this site : Mi Box Pro/Enhanced 3rdGen-Things I did after I get my Mi Box Pro/Enhanced 3rdGe - Mi Gadgets - Xiaomi MIUI Official Forumi updated to the latest i think
hi guys! i have tried 光芒体育 and it's finally loading
however, the fps is quite low, quite choppy, is that a normal problem or is there a setting i need to change?
this apk doesn't like xiaomi box. smooth on other boxes
Oddly, the big mibox no. But the new mini mibox all the acceleration are turned on w no problems.
only caters up to 1.3.50.. if you can find a more updated one, do share. Thnx..
This Article should work.
My Mi Box is running 1.3.73 rooted.
The original one will be this article
You'll need google translate if you don't read chinese like myself.
Thanks for the guide. Just one part I need to confirm though. The root app is launched from the pc and did you update to the latest firmware prior to rooting? An empty sdcard smaller than 32gb must be inserted in the box as well?
