Xiaomi Box Android TV Box
sputnikfire
for chinese shows, can use 热门电视剧 (hotdrama2) but i think this app needs a mouse. the user interface is in chinese
for those apps that use the mibox remote, u can also install kodi, then these add ons: drama24h, AZdrama, DramaGo. These 3 apps hv TVB dramas in canto voice and chi sub. dramago is the most updated n has the latest shows. azdrama and maybe drama24h hv some korean drama dubbed in canto. but not many and these dramas are quite old.
the downside to using these 3 is that the user interface is in eng, so might be hard for ur grandparents
last option is u install chinese aggregator apps like 电视猫(More TV), 布丁视频 (Pudding TV). can use both mouse and mibox remote. these apps have TVB, jap , kor drama. tvb drama are avail in canto voice and chi voice. but jap and kor dramas are not mandarin dubbed. also such apps might be hard for your grandparents to use coz a drama may hv multiple sources (different streaming sources eg. tudou, youku, letv etc). some sources are laggy in sg. some are smooth. so hv to trial and error to find which sources are good
WOAH WOAH, SPANKS!!!!:s12::s12::s12::s12:
lzhihao
bros... BPL is starting.. any apps or any recommend IPTV to watch the matches with eng commentary?
WAPT86
I'm not sure this has been asked before but I'm keen to find out after reading several pages.
What's the difference between the 3rd gen and 4th gen?
I'm using starhub optical fibre, which version is recommended??
Thank You for reading
Pengsp
Obvious- 4th Gen does not have usb, will have problem a connectivity, both may not have enough storage, no playstore, make life difficult for International users if not tech savvy enough. Not rec both, get other brand with playstore (min 8 gb) will make your life much easier.
ventin
Sorry noob in this. I got some questions...
1. connections is by WIFI. Why do i need USB?
2. The video is streamed. Why do i need high storage space?
3. What is the use of playstore when there are apps that can play/stream videos?
redname
1. some pple able to pull a LAN cable for the connection, so the USB can put LAN adapter
2. to be exact, it's for the installation of some but since can move apps to SD card, it shldn't be too much of a prob
3. some pple just like play store, for me, there are other ways to get apps, so no worries abt it
bunzbox
Is the content on youku and iqiyi Geoblocked now? unable to view a lot of the things as most of it are only playable in China.
AsteroidS
tvapp doesn't support current device - any idea?
tvapp.apk
fam_ami
I've a got a 4th Gen Mi Box bought two weeks ago from qoo10. Ive gotten the 1 year premium channels subscription however, most of the content is in Mandarin which I don't understand. Anyone interested?
yhw22
Yes. How much? :D
xiaowei09
Anyone able to install play store on mibox? the store i have now is not playstore and is kind of weird.
I would also like to know how to install google play service as i required it to open some app but could not download it from the pre installed store.
Thank you.
redname
Thank you.
use browser go to play store, get the url of the app then google for online download of apk
