In Shafa app, go to myapps, press menu button, choose setting. Viola! You will see Android app setting page and clear cache button.What's the difference between gen3 and gen5. Seller send me gen5 though I ordered gen3 and I thought I was lucky because it runs on Bluetooth remote control. But I realise the box internal storage isn't much.
How do I clear the app cache?
What is 5th gen? Is it referring to this?
NOTE: The 5th Generation is the 3rd Generation upgraded version.
http://list.qoo10.sg/item/XIAOMI-LIVING-1-YR-WARRANTY-ATTRACTIVE-GIFT-LATEST/417801809
Sent from LG using GAGT
Return n get a refund since its not what u intend to buy, or different from the description...
Good luck n all the best if u decided to stick with this latest model...
Sorry noob here.
Do I need to connect this TV box to my router via cable, or it can be done wirelessly?
Does my TV need to be a Smart TV?
Probably better invest in a Logitech k400 keyboard.
Works well with the mi box.
Don't install latest version of youtube. Search this thread for the working version.anyone manage to get playstore to work on mi box? not the mini version.
My playstore never work before since i bought it last year, but youtube is ok, but recently youtube stopped working. I tried all kind of method also cannot get it work, finally factory reset, reinstall the latest youtube, the app able to load, but when click on video, connection error.
Any advise?
Any advise?
Hi
I am using MI TV 2, my internet is fibre 1g myrepblic. I encountered slow internet speed issue. I use the mi tv to do a download speed test only average 2MB.
I also download shafa market and use the app 云视听 for movie/drama watch, the download speed only 100-200k.
What are your guys experience? Is this my ISP issue or china service limitation?
Thanks for the Help/.
Help! Kodi keep crashing on my mibox Gen 5. I tried installing ver 14, 15, 16 all keep crashing. Is there any setting in kodi that I need to turn off? I'm using stock settings
