gregory_choo
- Nov 7, 2007
The DNS works for all internet users or just some groups?
for anyone who want to unblock china movies site, or speed up the connection to china sites.
Wow! Seems better than Viewqwest freedom VPN
Sorry bro. I'm using SHAFA Market, can't find youtube
Hi guys, new to android box. Recently bought the xiaomi box 3 from china (enhanced version) how do i go about to watch movies and dramas on it? Do I have to root it? (apparently it says only china can stream)
sorry for the noob question.
(Update:Rooted using 360root but stucked at the steps where it requires to install the terminal emu. have installed shafa and changed it to english.)
Don't have to root. Certain apps is meant for china only, that's why you got the message.
You can change the dns to unblock these apps.
or you also can install other apps that don't have the geo-blocks.
see this fb post to learn how to unblock using dns.
https://www.facebook.com/groups/newtvboxsg/permalink/296967550651450/
Saw the latest Xiaomi box at Comex. How do we flash to the original android tv 6.0 that is used in the USA?
being too optimistic aren't uSaw the latest Xiaomi box at Comex. How do we flash to the original android tv 6.0 that is used in the USA?
Hahaha there should be a ang moh rom somewhere.
If you need Instant TV no choice have to use youtube and ultimately google service and playstore along the way. It's a b**** rooting the xiaomi and most of the online instructions dun work. I am open to any easier option (apart from getting one from Amazon).
I get what you mean. Miboxes are a pain in the rear to use and not recommended for people who are novices to tv boxes and dont have the technical know-how to troubleshoot when issue arises. I own a mibox 3 enhanced and its great value for the hardware specs but on the software side, its a great failure. The mitv UI is crap and there are many small bugs and issues which xiaomi dont bother to fix. Rooting and installing google services and playstore isnt that easy at all so i just gave up on the idea of doing. Now i am running into alot of software issues with box which factory resetting does not solve. The last step i can try is to reflash the rom but there isnt any stock rom file to be found on the internet.
If you die die want a box running on android tv OS, i say you just cough up the dough and get a set of nvidia shield android tv box. All these el cheapo china android boxes just dont cut it for one reason or another.
MiBox with Android TV should be coming out soon.
It is true that most of the online instructions dun work, but there is a set of working instructions for rooting of mibox, right at your door step.
Our friend Sayumpu Panjeena has post the instruction to singapore tv box facebook group:
https://www.facebook.com/groups/newtvboxsg/permalink/173217386359801/
