Xiaomi Box Android TV Box
chaddeus
Quick question. I am intending to get the Xiaomi Mi Box 3S / Pro. I want to watch Formula 1 on this device. What software should I download?
- Charles
BUYSELLTB
What to get
I am thinking of getting a TV box for my dad who loves to watch oversea shows such as wrestling and travelling shows.
I saw that there are a number of versions of TV box and am clueless on which one to buy.
Anybody able to give me advice on which box to buy?
Thank you in advance.
erwinrommel
Hi
Is there any app in Xiaomi tv box that shows live badminton coverage?
Planning to get one but never use a tv box before.
Thanks!
eauyong
Hi,
Just bought the android box with Kodi apps installed.
Anyone has any guide to connect/share media files/folders from my Windows 10 PC, so that I will be able to play them on the xiaomi box??
Use smb.
SMB is already enabled in Windows 10. Just enable the file sharing of certain folders containing your videos, music etc.
In KODI, enable SMB share, refer LINK HERE
eauyong
Depends whether you have 4K TV or not. If only normal HD, I would suggest the try and tested fully matured S805 based set top boxes from China at US$27-28 delivered.
If 4K is required go for S905 at US$32 delivered but system software for S905 is not fully matured yet and S905 uses more power so may face heating problem. S905X still have various problems reported so better wait awhile.
HKS_Hippo
Suspended
I have a Xiaomi box... just bought
Found out it is impossible to key in a URL in the pre-installed chrome browser
Any workaround?
The keyboard comes up and once i key in a letter it pops away
gregory_choo
Any workaround?
why use browser on tv box?
are you using mouse?
galliano
Lost the remote for my Xiaomi Mini tv box.
Any idea how to get replacement aside from buying from Taobao?
Any IOS app to use?
icearmour
the space in xiaomi box mini finishes quite fast when using kodi, is there any easy way to clear the cache and make more space..
also way to use official youtube app?
bran36
hi guys,
recently purchased a xiaomi gen 3 box. the white one.
came preinstalled with many apps for china tv.
there are very little HD channels for english/taiwan/hong kong/korean contents, so im asking if anyone knows if there is a paid iptv for this? deke tv looks good but lacking in local channels (my old folks need it). TIA!
hostet
Note: Only work on MI BOX 3S ENHANCED (White). Try at your own risk. Always update to the latest firmware before trying the steps below.
For those we want a step by step guide on rooting, install playstore and change launcher to Shafa launcher, you can refer to the step by step guide. https://baiviet.top/mi-box-3-enhanced-2016-default-launcher-rooted-and-google-services/
In case you screw up the process, you can always recover your box back to factory status through recovery. More info can be found here https://www.youtube.com/watch?v=iimAJEfsZXE
Press on the "OK" and "Back" button on the remote. Cycle the power to your Xiaomi box to access recovery. You may have to try this several times.
hostet
hi guys,
Search for IPTV or Huat88 reseller. You can ask for the channel list or buy the trial account to have a feel of the service before going for the annual package.
HKS_Hippo
Suspended
hi guys,
Install Kodi
Will work for android tv as well
gregory_choo
hi guys,
Buy a dvb-t2 set top box from qoo10 at about $25. Can watch all local channel in full HD, free for life.
bran36
actually i tried deke tv. not bad. still considering whether to pay for IPTV services. now, only lacking in korean live channels.
Install Kodi
yeap, tried. but not HD. thanks anyway!
yeap, am going with this option for the local channel. dont think will subscribe an IPTV service unless got a very good one.
rECKleSSfElla
what is the difference between the two?
which is a newer model?
:s12::s12::s12:
The black one is newer. Specs almost the same between the 2 except the white one is 6 core soc while the black one one is quad core soc. Also, the black one runs on android tv 6.0(not a big deal if you dont know what it means). Overall based on local seller price, i would go for the white one since its around 30% cheaper and slight better soc.
