Xiaomi Box Android TV Box
lotusnotes
I would like to ask gurus here if streaming will lag or not if I am on ST 3Mbps adsl broadband? TIA..
gregory_choo
I am using ST 3Mbps too. No problem with HD contents up to 720p.
As a general guide, speed requirement is about 500kbps for SD, 1Mbps for DVD, 2Mbps for 720p, 4mbps for 1080p for properly encoded videos.
Most of the time, the lag is due to the international pipe and the servers at the streaming site.
imacbie
Sir Greg, u using wireless or wired?
gregory_choo
------ Greg, u using wireless or wired?
I am using wireless. Have to make sure that the wireless performance is not lower than 3Mbps. I install speedtest.net on the box to test, to make sure that the internet speed over the wireless link is 3Mbps, same as wired connection.
imacbie
i do not understand why the box is having trouble with the connection using an original RJ45 converter.
it is so bad that the inbuilt speedtest refuse to run.
i can't stream anything wired .. so fustrating!
gregory_choo
Try using speedtest.net to test. It will help to isoloate problem.
yourxp
hey guys,
qoo10 got "extra service" to open more channels (HBO, star, etc.) for a small fee.
Is there a way I can get it without paying for the service? :p
or if not, only other alternative is cloudtv eh?
help help thanks!
k2010d
Anyone can advice how to check the storage usage of the 4Gb eMMC in the 3rd Generation box? Thanks in advance.
edwardwongcc
hey guys,
help help thanks!
Hi. Small fee meaning how much? After open is forever?
lingcw
For those wondering why the many recent cases of:
- "认证失效" on Xiaomi iCNTV
- missing channels and slow speed on 芒果TV
This is probably the reason: 广电总局约谈牌照方强调规范:将严惩跨界行为
In a nutshell, China authority is asking the 7 China IPTV licensees to strictly follow the guideline set down when they obtain their IPTV licenses... else they will be suspended.
takeshi_lum
i have plug in my ext hdd into mibox via OTG cable but it doesn't detects my hdd when i go into the app.
anyone encounter this before?
Knight_Rider
i dunno "how long" also.
some sellers are pricing this "service" between $7.90 to $10.
any guys can shed more light?
If you need to update firmware then you goto root again. Might as well "open" yourself and add what you want.
tckrto
the china forum posting rooting and enabling OTA update without affecting rooting is really BS lol. Lucky thing is F.O.C and only upon trying then realize.
Knight_Rider
The forum now very "clean" All software need permission to download. Damm.
magicsim
Anyone managed to install XMBC and can use?
I installed but have no video, only sound.
Can help? Where have I done wrong?
Thanks.
lingcw
Thanks.
There is a post earlier in this thread on how to solve this.
Anyway, from memory, goto settings -> video -> playback -> acceleration
under hardware acceleration, uncheck everything except for one that starts with "lib..."
Reboot XBMC and try.
