Xiaomi Box Android TV Box
Knight_Rider
2nd gen is classified as 1S under settings. Mibox 2 is for easy calling as there is no fixed technical name. So for rooting, firmware and apps goto be cautious which version to download.
stam
anyone using air mouse? which one is good for mibox3?
How do i have google store for my mibox3, i bought it from qoo10, comes with a english menu call XH or something..cant find googple play store...
Thanks.
_dXter
Long time no use xiaomi, now notice all the tvb dramas are removed! And movies added in a lot of US movies but a lot of hong kong movies were removed.... Also sohu server is so slow, that it is no point even watching their videos.
The point is? Better root xiaomi now. :D
shawnhalu
Hi guys, new to android tv box, i read thru the pages but cant decide yet, is there any other brand that can compete with xiaomi gen 3? I dont know which to get man.
can someone advise me? haha
tckrto
Android Mibox remote apps v3.4 now can mirror whatever tv display onto your handphone and I try using xbmc keyboard it works! Haha save money buy air mouse liao.
lingcw
xiaomi box 3 can root to get xbmc?
Below applies to Xiaomi Box 3 only:
1) You do not need root to install XBMC. It will play up to 720p without issue
2) If you root Xiaomi Box 3, you will be a able to change permission on some system drivers which will allow XBMC to better hardware decode the media files. ie. 1080p will play smoothly.
If you just want to play with the add-ons, I believe no rooting is ok.
AhHu83
Anyone knoW how to resolve the lag streaming for the movies and drama that provided by the 3rd party apps?
Btw i am on singtel fibre optic 100mbps plan.
tckrto
Which app is laggy? So far VST, Togic, Youku, iCNTV not lag for me btw I am on M1 fibre 100mbps.
AhHu83
Basically most of the apps which you hat quoted above.
Hence i am desperately need some good advices on this issues so pls give me some tips bcos my wife already out of patience with this box.
titiju
Could be weak wifi signal. Did you try testing your connection speed with xiaomi built in testing tool? It's under settings. You can try to pause the play for awhile and let it buffer.
