Xiaomi Box Android TV Box
hitme
find out the ip no of your tv box.
log in your router and go to DMZ, most likely in the advanced setting page.
key in the ip no of your tv box
Tried but can't find dmz setting in my router setup page.
Mine is Starhub cable. Using their provided Cisco router.
Rivers
hi guys, which app and channel can I view bpl matches at? been trying to search but can't seem to find it. thanks.
ricothp76
@ PSYDUCK Does it lag/delay when streaming EPL?? Am considering on getting one.
Just got a mibox and would like to share my experience. Using the 光芒体育 app for my sports. Quite a number of channels inside but i only use the astro 1,2,3 and 新视觉 (chinese commentary) so far.
Tried on past weekend epl matches, very good streaming, quite clear (but not in HD, acceptable to me), no lag (using orange 200mpbs). Only thing is there is delay of about 2-5 minutes of actual match time. Discovered when I compared vs live commentary on websites. So you are not getting actual "live" coverage.
But I am not complaining as I am getting delayed "live" coverage at minimal cost :s13:
tckrto
Astro delay is about 2mins. The other chinese one is 1min. But better the nothing. It's free or should say 1 time cost for buying the box :D
imacbie
Anyone who has the apk for this chinese TV for sports?
For the love of bandwidth, just backtrack a few posts b4 posting...
All the details are mentioned......
Goodness...
And if u are misunderstanding what he posted.
Which I believe u are, I think he meant to say the channel with the Chinese commentary.
It is within the same apk for the astro channel.
If I am wrong...
I sincerely apologies..
tckrto
U masters still donno how to read england ah?
光芒体育 is a standalone app.... where to download please copy the chinese words and paste in the search tab lah. Dr Choo got post before liao.
**** too much ATB liao lah. Until your big head function like small head LOL!
InnovaIQ
The Apk could downloaded to the thumbdrive or HDD, then I will mount it and open apk to install into my mibox. I am asking apk instead website as google has many. Thanks.
boneyrag
hey guys.. i have a couple of questions to ask.. i can't seem to use icloudtv? it doesn't load and there's always some error when i try to stream any shows.. i've also used the speedtest app in the sofa app, tested my speed to be good enough for "chao cing" but when i'm using apps to stream kids program, it buffers on "chao cing".. is there anything i can do about this? TIA :)
*forgot to add*
when i switch on wifi, the speed goes up to 5mb.. when i use LAN cable, it goes all the way down to less than 1mb.. usually around 400~500 region
gwennliu
*forgot to add*
All these IPTV apps does not necessary works on all ISP. So, need to know who is your ISP. If you use traffic light ISP, most likely they block or slow down the feed. Or make it don't work.
gwennliu
myTV sg version, works on some ISP. Try it, if can work, let us know your isp and speed.
edit: 13/9/14. Just found out it is actual china version, works better if using china vpn or hola and set to china
download from here
链接:百度云 请输入æ**å*–密ç** 密码:hgx4
MyTV works.
ViewQwest. 100Mbps.
But I usually watch it on PPTV. For example, 使徒行者 comes with both mandarin and cantonese version in PPTV.
MyTV problems is it always keep for 5-7 days like that. If I travel for 5 days, and I come back, the show is gone. So, I would go to PPTV to search for the show and watch it.
Take note, the PPTV on ViewQwest network is full China version. On other ISP is "International version."
gwennliu
Don bullsh!t lah. Only iCNTV lah HBO can watch via xbmc or other apps.
Actually, if I may input some of my observations...
Some of these app, such as Togic or HDP Live TV, can define you own channels. If you can find a good RTMP TV streams of HBO or Fox, or Discovery, etc, then, you can use them to watch it.
The problem is, these TV network provider are also looking out for such illegal live TV feeds. so, once the link is available, almost immediately, the feed is not usable.
If you look into Shafa Guanjia (Sofa Butler) App, under the setup page, there is a place where they provide 4 different IP TV streams. One of them are Hong Kong and Taiwan feed. And I think one of them are oversea feed.
I also found that CloudTV, the one that they sell in Sim Lim is extremely fast and clear. And I use PayPal to buy month by month subscriptions. Inside got all the HBO, CNN, Discovery and so on.. 161 channels.
I am using ViewQwest with 100Mbps. +FreedomVPN
just my 2cents
