Xiaomi Box Android TV Box
PatrickL33
OK. I manage to download the add on since can't find the repo but doesn't look like the Xbmc can access the USB. Any idea?
ekardo
actually still dun understand why need xmbc?
I installed and it's virtually an empty shell to me..
so far, shafa is good..
The Big Bang Theory
yes LeTV lags, netstar watch what one?
i actually bought xiaomi for my parents to stream HK and chinese drama/variety one
gregory_choo
the letv I posted earlier is a special version, most of the people have no problem stream it.
netstartv is good for chinese/hk drama movies, it is based on youtube servers. If netstartv still lags, then have to throw away your isp. need mouse to operate
The Big Bang Theory
which paid iptv have you tried?
only tried the one gmarket seller provided, it was quite smooth, but very limited live channels....
use buting or tuzi..all good for HK or PRC drama
tuzi is which app ah? surprisingly 布丁 works for me, im getting smooth speed....is it this timing no1 clogging the network? last time i tried was at night....
thanks bro, but the leTV i try open it just auto off, won't open...
netstarttv works tho, but i don't think my parents know hows how to navigate....
btw how to uninstall apps ah? i tried go setting but dunno is which one
one more qn, can i use gigabyte network USB 3.0 on it? coz 2.0 USB-RJ45 ethernet only supports up to 100mbps, but im using 200mbps
The Big Bang Theory
tuzi very lag also...
just now tried watch one drama show from pudding but it will stuck at 0kb/sec randomly...i need to switch to 480p then back to 720p again to make it rebuff again, and not everytime works :sad:
gregory_choo
100Mbps is more than sufficient for streaming. you can do 4k video with it
The Big Bang Theory
i understand, but isn't 200mbps would provide me an more stable connection during bad connections? e.g 100mbps im buffering at 200kb/sec, but 200mbps may give me 300-400kb/sec?
but i dunno whether xiaomi can support USB 3.0 gigabyte network or not
icyflame
Hi, you are guys able to login to YouTube. It comes with YouTube preinstalled but I am not able to login.
Wanna access my private YouTube videos so need to login. Thanks
