Xiaomi Box Android TV Box
icyflame
Hi, you are guys able to login to YouTube. It comes with YouTube preinstalled but I am not able to login.
Wanna access my private YouTube videos so need to login. Thanks
Looks like I need a suitable google play services apk. Tried aptitode one and it doesn't work.
gregory_choo
i understand, but isn't 200mbps would provide me an more stable connection during bad connections? e.g 100mbps im buffering at 200kb/sec, but 200mbps may give me 300-400kb/sec?
but i dunno whether xiaomi can support USB 3.0 gigabyte network or not
I don't think so.
The bottleneck is at the link between sg and china.
Juzme73
Android TV Box with DVB-T2 - watch local channels
Anybody interested in this product?
Android TV Box with DVB-T2 - can watch local channels
jhawk2820
100Mbps is more than sufficient for streaming. you can do 4k video with it
Overkill alr. if able to have a stable of 300kb/s you can able to watch movie with HD of 1080.
the bottleneck is the link between SG and CN. think VQ have a good reputation for good streaming for china show and provide freedom VPN.
I on yellow 100mb speed. so far ok except duration evening time.
Just Me
Got yellow isp meh? Anyway, freedom vpn isn't cheap.. I'll go for astrill vpn over it anytime
The Big Bang Theory
I don't think so.
Ahhh!! haha ya lo :( I guess i'll get the RJ45 USB 100mbps see if it can improve..
even pudding is very unstable in non-peak hours like 3pm+, giving me 20-60kb/sec...
hi, sorry if i confused you with my example haha, it was just an random figure i popped out...
which app u use ah?
m1 has this 1 giga speed with stated no Btorrent throttling..i wonder does it affect streaming too...
btw if i purchase VPN for my m1, will it be much better?
BombVoyage
want to buy one to try. just read through the thread.
so in short, buy the box, connect the cables, power up the box, install apk of which streaming site you want to watch then okay liao?
The Big Bang Theory
i just bought mine recently...
setting up the box is fairly easy, power+wifi/ethernet+HDMI.
i bought jailbreak one from q10, so some apps like pudding is inside...and ready to watch...if u can stream smoothing :sad:
which ISP are u using?
jhawk2820
which app u use ah?
魔力got good source of different varieties show, Tuzi too.
depend which VPN you using, some exp, some cheap.
usually Fast not cheap
Cheap not fast.
jhawk2820
buy non-root version and save a bit. rooting is pretty simple unless you really got no confidence.
after rooting can download any apk you like.
the firmware must be below 1.3.53. 1.3.53 version unable to root.
glx
M1 fiber 200mbps here
I use the following apps because they aggregate from multiple sources, so for the same drama I can choose the faster source to stream from.
VST全聚合2.5
pudding
魔力视频
For a show, it may have 1 or multiple sources to choose from. These are my experience so far.
LeTV and MangoTV only start buffering then very smooth playback all the way
腾讯 very fast but the lowest quality
Youku and iQiYi are slower than LeTV and MangoTV with occasional buffering while watching. Still very watchable. Performance very confusing because some shows are very smooth, some shows are buffering occasionally
Sohu, PPTV source totally can't connect
Generally, can watch many shows without much problem, but wish to ask if can improve the speed further as some shows only have youku and iqiyi as the source.
Is there anything to install to help to improve the speed of youku iqiyi? Or can even connect to sohu or pptv?
Thanks!
