Xiaomi Box Android TV Box
Blindaim
If you have another full HD tv available, plug the mibox into it first so that you can see and change the resolution setting to 720p
deschng
Hi sorry quite confuse bout this. I know I could get this from qoo, but which one Shld I get? Some is selling for $50+ and 1 is selling $100+ jailbreak version. Thanks in advance.
jhawk2820
is the item are the same model for 50 and 100
50 are more likely ver 2 and 100+ are version 3 aka enhance version which the latest model.
hotyrole
Hi Guys,
Just got my version from Tabao.
Around $80+ for a "jailbreak" international version. v4 , 1G
Seems to me that there is some connection issue with Starhub
Anyone using any proxy ? What's the cheapest one ?
jhawk2820
Hi Guys,
80+, i doubt it the latest version which is enhance version. Check if it dual or four cores. 4 cores is the latest with CPU speed of 2.0 GHz
hotyrole
I checked, it is 4 cores, 2 GHZ.
Exclude shipping. , which is RMB2 during the 11/11
Yepyep
limcheekong
Hi bro,
I also regretted upgrading to 1.3.61.
Are you able to install Cracked Youku apk? I am not able to.
Suspect it is the new firmware that's blocking.
I can install Cracked PPTV, LETV and Xunlei.
Both PPTV and Xunlei works but LETV is not able to work.
It got a message that says Application Under Verification by CNTV
jhawk2820
Yepyep
i see, you brought from china (Taobao) directly, the 80+ should be the enhanced version.
if i you, i buy un-hacked version and root myself. pretty simple and straight forward to root the device.
hotyrole
yep, i know right, should have save some $ with my own hacl
it's ok. quick check, any other quick VPN service ?
galliano
Question: just received the Mibox (latest gen). And its OS is ver 1.61.
Tried installing Shafa or Tuzi launcher. Both unable to allow me to set as default.
Is it cos I'm in ver 1.61?
In fact, the box has a 1.65 update too which i have not done so.
jhawk2820
its due to the the xiaomi tv OS which disable to select any other launcher.
i1magic
Wah, this 3rd Gen Xiaomi Internet TV Box selling for <$50 (self collect). Is it a good buy? Legit?
Item : Xiaomi 3rd Gen Android Internet TV Box 4K Version 1GB/2GB RAM
Price : About SGD$50
Source :
Qoo10 - Best Christmas Gift 3rd Gen Android Internet TV Box III 4K Version - 1... : TV/Major Applian...
i1magic
It is $80 after you choose all the cheapest and chinese version options.
Source :
You are right. Sorry, my bad. One of the so-called option is compulsory. So if English version, the final price is about $109 liao.
Crap.
alexkidd
Crap.
Cheapest can get is using the $11 7-11 coupon + $2 cart coupon on qoo10 is $86 self collection
