Xiaomi Box Android TV Box
hotyrole
For some (like myself), it matters.
If not, you are welcome to pay :) haha
Anyway quick question, any new version of xiaomi box coming out ?
glx
Might be coming to SG soon. Someone posted a screenshot showing mi box on IDA website many pages ago.
edmund7
Anyone recently experience this problem?
Also when I check the speed of xiaomi and the speed is basically near to
0 kb/s.
- "认证失效" on Xiaomi iCNTV
I think ICNTV got problem and is affecting some of the apps.
Please advise?
stam
anyone using XBMC / Genesis on Mibox 3?
Why is it the streaming progress/duration bar won't display the correct timing(the slider stuck at 0:00 even after playing for a while) and dont move according to the movie play?
PatrickL33
Is there anything I need to enable to do airplay. Every time I tried. It's showing the transfer speed then back to main screen
xtakoh
Hi anyone here is itchy handed like me who changed runtime to ART? Now I cant get my mibox running and its stuck at ICNTV screen. Anyone can help please?
ekardo
dunno what happen the UI of mibox changed...
and not only that...last time when I click home or back button, the app closed...but it doesn't...how come ?
jhawk2820
Can XiaoMi Box work with Singtel fibre?
If use VPN will it affect other connections? for example, my pc's connection.
Please advise. Thanks alot.:D:D
VPN only affect on the device that running the program. unless you setup your wifi router to have VPN, then the whole wifi signal is VPN.
jhawk2820
power off your tv box. press and hold both home and menu button at the same time and point the controller toward your TV box. ON power and wait till it goes to recovery mode. you reset everything and restart. by do that, you should able to solve your issues.
jhawk2820
0 kb/s.
Please advise?
most likely is your internet service provider, or do you run another program like VPN which might cause the problem
lwm999
Actually need VPN or not, depends on what you want to watch using mibox. You need VPN if you want to watch from LeTV, Youku, iQiYi, etc because all these are based in China.
Qoo10 those premium channels are live stream IPTV which you may not need VPN to watch.
I am on M1 using 网趣云加速 recommended by imacbie bro here.
The website is wangqu.cc. This VPN is for china.
Its an app and very easy to use. Just open the app and press a button to activate/deactivate.
I am not sure about other VPN, still pretty new to android tv.
Does your current VPN has china server?
I have some questions, hope someone can help:
1. Seller 1stshop said VPN is "built in" into the box hence no need additional VPN to watch LeTV, Youku, etc. Is it correct?
2. If cannot and have to use 网趣云加速, have to pay VPN subscription right?
3. How about use this method instead of VPN?
在 Android 上使用 Unblock Youku 观看国内视频 – 尘埃è*½å®š
4. I am on M1 200 Mbps fibre. Anyone has experience is it lag to watch?
Thanks.
glx
Thanks.
1. I see they say they installed a free VPN, not "built in"? No such thing as "built in" VPN.
2. No free lunch in this world
3. Never try before. But look like need to undo the wifi setting changes everytime you want to watch non-china stuff.
4. I am on M1 200 mbps too. Without VPN. Only LeTV can watch smoothly most of the time. Watch live EPL on Astro also no problem. Youku, iqiyi will keep buffering.
lwm999
Thanks bro for the answers.
I am also puzzled why the seller said VPN is "built in".
You mean without VPN, you can watch LeTV and Youku directly?
Are you using wifi? I thought of getting the USB->RJ45 cable for wired connection but not sure if it helps.
The Big Bang Theory
I contacted 网趣云加速 support staff regarding the need of resetting xiao mi tv box if did not turn off their application upon switching off the xiao mi...
they tried their best to resolve but still no luck, they say they can only hope xiao mi update their software to resolve this issue lol
glx
Yes, I using aggregate app like VST, moli or pudding, without VPN can watch LeTV smoothly most of the time. Youku will keep buffering, not very watchable unless you change to low resolution quality.
Yes I using wifi, I got the USB -> RJ45 as well. If you got the Asus dual-band wifi router from M1, I think no need to get. I feel wifi is faster after testing.
