gregory_choo
- Nov 7, 2007
Anyone noticed that youku is missing from Shafa now
It is hidden, not missing.
Download and run [电视必备], then you can find youku, QiYi, tuodo...etc.
Can share link to buy mibox 3 from Lazada at 85?
Did you try to do factory reset? Or do you have USB to ethernet adaptor to test if that works?
Did the factory reset to default & finally can get the WiFi detect, thanks, but find that movie is not watchful due to frequent buffering, mine is on Singtel fibre 200M, router is Aztech 7002.
still trying use th default Icntv app to watch the free movie, very lagging , every 10 sec it need-buffering.Have you tried running speedtest? I'm getting almost 100mbps on 5GHz wifi and i have 100mbps starhub fiber broadband. in fact wifi is faster compared to ethernet via USB to ethernet connection which I only got 50mbps.
I used org.zwanoo.android.speedtest.apk to test.
so far streaming is quite good for me.
What application you're using to watch movie?
XiaoMi Mi Box 3 Quad Core Android 4.4 Smart TV 4K HD Box | Lazada Singapore
Can watch in Singapore?
My friend bought a unit at Sim Lim for $120, the salesman say if we bought the unit direct from China cannot watch they modified the unit in order to watch in Singapore.
Please advise.
hi, just to check if i can watch EPL via xiaomi? (be it via paid subscription or streaming)
Please advise.
can xiaomi also stream live EPL matches and champ league match?
Yes. I already mentioned the app 2 posts above yours.
is it possible to change to English language on the box?
