Or Samsung Galaxy M51, export set only. Screen and battery r huge, there are some discussion on going too, at Samsung thread
Same aspects ratio?
My dad's Max 3 has severe battery drain after update and reset. Any issues with battery life?
Posted from PCWX using Redmi Note 8 Pro Ocean Blue
Do factory reset. It solved my battery issue but my mic issue is still not fixed..
Mine was updated to MIUI12 as well, I did reboot the phone and have not noticed any significant battery drain...so far, so good.
Sibei heng har. Today after update phone no lag
Quick question. Given that I think MI Max 4 won't be out, any recommendation for similar size phone? Thanks in advance!
Wah. Updated to MIUI 12, super slow charging on phone. Takes 3 hours instead of 1.
Try to use the original charger, mine is okayWah. Updated to MIUI 12, super slow charging on phone. Takes 3 hours instead of 1.
I went to lite mobile. 1hr done.anywhere we can change batt besides SLS
Thanks. What's the dmg?I went to lite mobile. 1hr done.
