Xiaomi Mi Max - Part 2
kelvinti
kelvin, last nite, your tips 7511 tio flipped prata(starter).:mad:
1157 it was! A humble $2 (system bet) winning of roti prata supply lah!=:p
Don't say I never jiu you all! ok! :s8::s22:
The MIUI version numbers are quite "hot" de especially those with a "double digits" version numbers. Double digits, cost is also much lower for system bet. :s8:
DRAGONGUY
1175 it was! A humble $2 (system bet) winning of roti prata supply lah!=:p
If got buy, can become my budget for mi max 2 though (sd660 version if any). :s13:
Too bad la, dont have such thoughts and luck.
kelvinti
No wonder i find that number so familiar! :s13:
Actually also wont think of buying de la.
Ya! ;)! At lease got some spare/extra cash for whatever purposes lah! :s22:
So, hits and misses is the name of the game! It is indeed, luck! :):s8:
May Lucks be with all of us! :s22:
Okay! Stop the 7511 here before Admin arrows us to EDWM! =:p
kelvinti
BTW, today got $80/$50/$10 cart coupon by Qoo10.
Those who wanna buy Mi Max can look see look see in Qoo10. :)
kelvinti
I don't see any $50 coupon.. and the $80 one requires a minimum spending of $500 :D
Oops! $80 and $10! Piaseh! =:p
BTW again!
The cheapest 64 is from this Seller now! :s22:
The cheapest for 128 is from this Seller now! :s22:
*Excluding any discounts or rebates that you can use!
kelvinti
Root experts,
A noob question.
How can I see and access the /system/ folder on Mi Max? :s8:
Does my Mi Max needs to be rooted or there are ready-made apps or PC pgm that I can install for the said purposed?
Coz I wanna access the stock tones folder..! :D
kelvinti
Folks,
Here comes there Global Developer 7.5.18. :)
Incremental update or full update.
Incremental update didn't work for me.
keichi_k1
Who are the reputable sellers for Mi Max on Qoo10?
Also would anyone be able to direct me to the instructions on how to flash the ROM?
Or if I do not want to flash the ROM is it ok?
Can I just remain on the ROM out of the Box?
kelvinti
All sellers are okay as far as Mi Max is concerned.
NewStar always has the best price! (Most of the time on Qoo10).
It's good to flash to official Global rom for full integration of Google services!
Else, you may encounter some abnormalities and apps comparability issues if you remained on China rom out of the box.
Unless, you are lucky that the seller has preloaded the official Gllobal rom for you, or you can request the seller to do so if the seller is willing to!
Call the sellers to check!
