Xiaomi Mi Max - Part 2
kiddykong
No leh. Still as speedy as before.
Probably the over-used of battery saver could be the culprit actually...!?
when typing my first reply into whatsapp, the first message will take like 1-2s to ''appear on my phone screen''
dk what is wrong
kiddykong
is there a setting to keep the network alive while the screen is sleeping? I want to upload 1000 files to onedrive, but after 8-9 files the screen turns black and when I wake it again I see the transfer is interrupted at that point.
Also how to enable file mangagers to use usb thumbdrives? They keep saying I must 'select the usb drive' but I cannot see it in the file manager apps at all.
can consider checking your battery device settings. see if it is the miui killing your app from running in the background
they have some ''smart miui'' battery saver thing. just turn off the restriction on that.
kelvinti
eu rom 7.11.23 OTA goes live. :)
SafetyNet passed as well for eu rom 7.11.23 (Magisk Manager 5.4.3) :)
kelvinti
How is the ROM compared to the Beta one? Auto-brightness fixed ?
It's as speedy and as smooth as the Beta rom! :)
As for the Auto Brightness...Haiz!:o.... Xiaomi insisted to stick with the new Auto brightness logic! It's not a bug after all! It's the new logic as per said! :vijayadmin:
Anyway, not an issue for me as I have rooted my phone and I have changed the logic to "false" in the helium.xml to "Disabled" the new logic! :)
As for the WhatsApp custom notification. It still recognizes tones in the root/sytem directory only to produce notification sound. So, again, I have put my custom tones in the root/system/...folder so that my WhatsApp can play my custom tones! :)
ngbc
Thanks for the feedback, gotta flash it soon ...
kelvinti
However, bear in mind that both the Assistance Card (By Xiaomi) & Face Unlock (By eu.Xiaomi) which are found in the Beta rom are not available in this eu Stable 9.1.2.0! :s22:
I'm okay without that 2 features coz I don't use them at all! :)
Techno Pride
Is Xiaomi Singapore willing to replace the battery for export sets?
I'm concerned about battery authenticity when getting the battery changed by shops outside.
Sausage
I just noticed something about my mi max space.
It's a 32gb model but apps show only 28gb total, and of that I can only use 14gb for my own things. There seems to be one 14gb partition for applications, and another 3 gb partition for system use.
Is this the standard arrangement? They specifically create a 14gb partition for apps?
ngbc
Thanks, I don't use them too ...
