Xiaomi Mi Max - Part 2
maisatomai
Just tested it again on another iptv app, some channels I think cannot handle the decoding, the audio is always infront/behind. No issues with android box. Using hardware decoding and software decoding same lag. I wonder what we can do to help improve the speed..
can sic the iptv app
kelvinti
Hmmm... China rom is already at 8.2.3.0...
Where is my Global rom update from the current 8.2.1.0...?
Anyone on global has gotten it yet as a random user?
CyberTron
Have a 32gb model updated to official global rom. Out of sudden yesterday cannot connect to internet using 4g
Wierd is insert another sim (same telco) can work
Put the original sim on another phone also no issue
Try clear cache data. Reboot or power off and on phone also cannot.
Last option would be backup, factory reset, restore
Anyone encounter such problem before?
cool_ocean11
Just bought a set from new star, may i know if theirs is official global rom? how to check ah? sorrie newbie here
deckcard
Yes it comes with global stable rom but not the latest. You can update to the newer version if you check for update. I ended up downloading the recovery of the latest and update via the updater app and it works
cokiee
The prevailing suggestion here i believe is to flash it yourself anyway, to one version before the current, then do an update to confirm that it works.
Sent from Xiaomi MI 3W using GAGT
xKazeolus
