Xiaomi Mi Max
walkofwinners
*nvm found youtube video about dismantling.
*Important just use all the force to pull your sim tray out. There is no way you can dismantle it when your sim tray is in.
I dismantled half way then realize==
Anyone know how to dismantle this phone? I tried the 2 sim hack but i forgot to trim the back and i force the sim tray in... I Kei pa lan, now the sim tray jam liao even though the 2 sim hack works.
Try slotting a piece of paper or something thin in between the sim slot and the phone so that it dislodges the tray and the phone
mjzsakae
Already warn a few post back. This is very risky rework unless you do not planned to remove sim in future.
Mine is pretty tight as well.. But still manage to take it out.. But I need to shake the Sim tray left right left right a bit then can pull.. My Sim card has been trimmed a bit..
rECKleSSfElla
Ermmmm dots? No i dont see it. U mean the full screen tempered glass?
Frankily speaking i can't see the dots...
Upon closer inspection, it seems like the dots are on the glass sp itself rather than the screen. The only way to confirm would be for me to remove the glass sp and see but then i dont want to have to reapply the sp so boh bian my dad will have to live it:s13:.
Oinkize
If it is not causing usage problems then just leave it... Glass sp very prone to crack with removing...
rECKleSSfElla
For those who dont know what i am talking about, its something similar to this(not actual pictures of my set)
Did a search online and it seems certain glass sp will have this problem. I bought my glass sp from a shop at sim lim. Generic no brand stuff cost me $15 and the quality is like this:s22:.
qyc_91
I think it's the sensor for the screen, but the screen protector just happened to make it obvious under certain light condition.
allanzzz
It's the screen, not the sp
Sent from LGE LG-D855 using GAGT
wildfaye29
anyone bought from newstar via lazada?
do they flash any roms on it? or stock phone/rom from china?
I prefer stock un-rom-ed phones.
tofubean
Wow the problem so obvious. If it's sp problem, better buy another sp and re-apply. My sp from taobao totally don't have this problem - only 16.80rmb some more, about $4-5 including shipping. It also has that tool to help you paste the SP straight. :s13:
Give u the link in case u want to buy - https://world.tmall.com/item/531825958585.htm?spm=a312a.7700714.0.0.XsMKqF&skuId=3176413252508
Nakedtoes
Isst full coverage? If full coverage isst adhesive on the side to paste type or like normal tempered glass whole piece paste down
DRAGONGUY
*image cropped*
Oh this full screen temper glass, i can say all will have. The common characteristics on its own. It depends on brands also, some will very obvious like urs, some minimum. In the later part, rainbow patch or oil patch prone to appear in most scenario.
Mine bought from taobao and it is that less obivious under those "抗蓝光" type.
tofubean
When i paste the sp, i dun see the sp slowly stick onto screen like other transparent sp for other phones. So ya i think adhesive on the sides and top bottom.
