bbcccc
- Jun 7, 2011
yup.
will buy the yummy nasi lemak tml from lucky plaza too...
opt pickup better. can check on the spot.
yup... self collect.
buying 2nd time from this shop le...
Buying?![]()
Play store works but my contacts are not syncing...anyone can please advise?
In addition, you need to go into Permissions Manager and Allow it to modify/overwrite Contacts...now got it all synced.Download and install google contact and google contact sync, it will get your contact sync with your phone.
The set was opened in front of me. The store assistant helped me to install Google Play.NSE sets are sealed or opened to remove the charger?
Qoo10 goes for 348 but 1 month warranty, additional $40 for 12 months.NSE sets have to go thru qoo10? or can directly dropby their shop to buy on spot?
In shop $380 for 12 months.
Mine has a minor issue with the capacitive button light. The "Back" button light is very faint but the button works perfectly.
Just notice at home, coz it's viewable directly ahead when holding it normally. I'll give them a call tomorrow.why never ask for exchange? mine seems equal.
