Xiaomi Mi Max
i1magic
Those that don't like the above, can get this one.
Item : Ultra thin slim transparent clear crystal TPU gel case cover universal back skin
Price : About SGD$1.80
Source :
http://www.ebay.com.sg/itm/Ultra-Th...hash=item2a691f841d:m:m4MpxIBSjXlXwR1EYI4YHdA
DRAGONGUY
wahahahaha. guess me and kelvinti kena chop carrot head. but well it still serve the same purpose i guess lol!:s22:
anyway i order sp from taobao and comes with free clear silicone case also lol.
PholkLorr
Am considering between the redmi note 3 pro and mi max as replacement for the craptastic LG g4 (as u all know, g4 failure rate is absurdly high).
I compared the specs between the mi max and redmi note 3 pro and notice that there isn't much diff between the 2,other than the fact that the mi max has a much larger screen. Is that right?
Cause the cheapest redmi note 3 pro now is 243 dollars and the cheapest mi max is 299? Both also cannot use coupons for discount.
Edit: lazada has mi max for 284.9 + 2.9 delivery. And that one can use discount so probably cheaper.
Nevertheless, is it worth paying 40 bucks more for the main difference of bigger screen? Performance and features wise it's almost the same right?
DRAGONGUY
there's one more difference. RMN3 only 4g + 2g network whilst Mi Max is 4g + 3g network. If u don't use dual sim at all, go for your needs and pocket loh.
kelvinti
Hahaha!
Bo pian lah. That's street price in those shops...
Chopped me $6 is better than 6 dents if I suay suay drops it during first few days...
Close one eye lah.
i1magic
Ok. If you want bigger screen, higher battery capacity and Android 6.0.1, go for Mi Max.
If not, go for Redmi Note 3.
amazingone
well, if it comes cheaper than Mi Max, that i guess wont be an issue. But hor actually that dark line border that thick is nicer comparing on Mi Max somehow. :o
Not cheap..
4GB+32GB= RMB2299
4GB+64GB= RMB2499
4GB+128GB= RMB2799
Though it comes with a 2K display but a smaller battery as compared to Mi Max at only 4500mAh.. :o
Sent from Sumire using GAGT
DRAGONGUY
Holy cow!! it is 6.6" super amoled screen!! with 4400mah batt!!
processor is higher speed but not sure performance as I nv used hp w/o snapdragon (other than sgs n2 exynos).
I guess sure to put up fight if it supports 4g + 3g network.
specs read from here
Vento95
Thanks Dragonguy - will try this
Do I have to worry about turning off/on Windows Signature verification on my win 10 PC?
Would I have to reinstall Google Playstore after flash the ROM?
DRAGONGUY
Np, if my memory serves me right, i did not touch anything on the windows signature verification.
Yes, you will have to reinstall google playstore if you flash official china rom.
