Xiaomi Mi Max
khaine
Outlook Calendar cannot Sync with Xiaomi Calendar nor Google's
Hi everyone!
After reading all the posts here for the past weeks, I finally decided to get the Mi Max (via Qoo10 @$304 including delivery, China set with MiUI 7 global rom and Google Play installed)
Spent last night transferring all my stuff from my Galaxy Note 4 (it now feels small....). Encountered some issue when moving icons (resolved after I changed the screen effects back to slide and use the Move App option).
Everything is great except for 2 things I found:
- Battery drain, charged overnight to 100%, woke up, checked FB, email, update a few apps and its drops to 94%...seems too fast compared to what I've saw on various reviews
- Calendar doesn't sync. Setup my office Outlook, got the emails but the calendar events don't sync and appear. Installed Google calendar and the same thing as well. Even my Google account calendar events do not appear in both. Sync up several times, but no go. The only thing that appears is the SG Holidays calendar (Google)
Anyone has any ideas? Thanks!
kelvinti
Hi everyone!
It is best to flash it to global rom. One and for all to solve all the abnormalities which includes the issue with Google related apps that comes with China rom. :)
kelvinti
Why is that only the Gold has good prize?
My gf wants a Silver. :(
Again, conflict of color choice between 2 of us again! Lol..
i1magic
Hi everyone!
That's why I want to find out how to flash official global ROM for Mi Max first before buying it.
Also after I buy it, I will flash it with global ROM, test it for awhile, confirm ok, then switch over.
kelvinti
Flashing to global rom is very simple as long as you follow the flashing steps correctly.
All can be done in less that 15 minutes and your phone will be rebooted with a fresh global rom and phone. :)
khaine
Hmm...I thought I am already on the global ROM -
MiUI version - MIUI Global 7.3 Stable 7.3.11.0 (0MBCCNDC)
That's what I see when I got to About Phone
Passer
Bro, also interested. When you get yours, can check what rom it is using?
sure! hopefully if i can still remember to check before flashing to global. I'm already planning to flash to global once i got it.
DRAGONGUY
This is vendor rom aka modified rom. Flash to official global rom if ur set is 32gb.
kelvinti
If I'm correct, that is a very old and outdated and unknown/unpublised China rom.
This is the latest China rom: Version: V7.5.6.0.MBCCNDE (MIUI7).
This is the latest Global rom: Version: V7.5.3.0.MBCMIDE (MIUI8). <---- This is the rom you should be using!
tan1688
Where to get tempered glass screen protector ? i haven't got mine yet, seems the tempered glass screen protector sold on market is not full screen ?
khaine
Darn....thought I don't have to flash..
I downloaded this the rom from here ->
http://xiaomitips.com/download/miui-7-5-for-mi-max-v7-5-6-0-mbcmide-global-stable-rom/
Downloaded this -> miui_MIMAXGlobal_V7.5.3.0.MBCMIDE_267a7c4439_6.0.zip
Then I just follow this instructions here? -> http://xiaomitips.com/guide/how-to-install-miui-7/
Rename the file to update.zip, copy over to the root of Internal Storage, then follow the process on the website above??
Correct process before I start??? :(
Do I need to unlock the bootloader??
1st time flashing a rom...last time only do rooting on Samsung phones...
kelvinti
Hold back!
You cannot use that method!
You cannot use Updater to update from a China rom to Global rom.
You will have to do a total wipe out method of using a Global Fastboot rom, and you must be prepared to set up your phone from ground zero again! However, it is just a one-time job and you will be happy forever!
khaine
Hold back!
You will have to do a total wipe out method of using a Global Fastboot rom, and you must be prepared to set up your phone from ground zero again! One time job and you will be happy forever!
Phew...didn't do anything yet...
ok, sorry but need you guys to guide me then...
1. Download the Fastboot ROM from here -> http://xiaomitips.com/download/miui-7-5-for-mi-max-v7-5-6-0-mbcmide-global-stable-rom/
This one: hydrogen_global_images_V7.5.3.0.MBCMIDE_20160523.0000.23_6.0_global_55a4896b43.tgz
Correct?
2. Then follow the steps here-> http://xiaomitips.com/guide/fastboot-bootloop-hardbrick-softbrick/
Correct?
Q: Need to unlock the Bootloader? Mine is not I think....
kelvinti
Correct?
Correct?
Yes! That is quite a good and clear guide. Follow it carefully. :)
The bootloader doesn't has to be unlocked. :s22:
DRAGONGUY
Simple steps...
1. Dl official global rom
2. Unzip it
3. Open miflash beta, select unzip rom parent folder, check "clean all"
4. Shutdown phone, then press vol+, vol- and power button at the same time. Phone will boot with vibrate and empty screen.
5. Connect phone to pc, wait for detect, then press refresh on miflash beta. Once detected press then flash button.
6. See screen and once ok, disconnect phone and restart
7. Wait for phone setup itself and voila, enjoy ur phone
