Xiaomi Mi Max
khaine
Simple steps...
1. Dl official global rom
2. Unzip it
3. Open miflash beta, select unzip rom parent folder, check "clean all"
4. Shutdown phone, then press vol+, vol- and power button at the same time. Phone will boot with vibrate and empty screen.
5. Connect phone to pc, wait for detect, then press refresh on miflash beta. Once detected press then flash button.
6. See screen and once ok, disconnect phone and restart
7. Wait for phone setup itself and voila, enjoy ur phone
Thanks everyone!
I'll try it out later...need to bring the kids out "hunting" and playing :)
Extracting the contents of the ROM to my computer now...I'll do the rest later tonight :)
Will update
khaine
Simple steps...
2. Unzip it
1. Dl official global rom *Done - hydrogen_global_images_V7.5.3.0.MBCMIDE_20160523.0000.23_6.0_global*
2. Unzip it *Done*
Question:
a. Select the main folder or the Image folder?
b. "Clean All"? No such option, but from the other website it's to select the "flash_all.bat" for the Fastboot Script option. Is this what you are refering?
Step 6 and 7 here:
http://xiaomitips.com/guide/fastboot-bootloop-hardbrick-softbrick/
Thanks!
rECKleSSfElla
2. Unzip it *Done*
Question:
Step 6 and 7 here:
Thanks!
You should use miflash beta(which has the clean all option) instead of miflash tools.
FOLLOW THIS LINK STEP BY STEP TO FLASH THROUGH EDL
http://xiaomitips.com/guide/how-to-flash-miui-fastboot-rom-on-mi-max-with-locked-bootloader/
Step by step explanation with big big pictures to guide you. How hard can it be?
DRAGONGUY
Or u can search this thread for my posts many many many pages back with details but no pictures. Personally i find this method is easy and less confusing though...
Edl method as per xiaomitips have 3. I think mine is the third one, but based on own experience.
Edit: yes bro rECKleSSfElla link is the same method i post, with more details and pics
Devilsire
anyone facing issues downloading apps via googleplay over 3g/4g? - awaiting wifi
googled and read abt soloution settings in Tools-Download-Settings, but under miui8 there's no settings available....
EDIT:
Solution found, Under Security-Data-RestrictData-System- Tick the "Download" App
sumkong
i tried to download the "My Transport Sngapore" app but it said "Your device isn't compatible with this version". Anyone facing this problem? I am using miui 8 global 6.8.4 beta rom.
s1mple
Lta issue, somehow they just ignore xiaomi user.
Need to sideload the app as of now.
KalTorak
Hmm...I thought I am already on the global ROM -
MiUI version - MIUI Global 7.3 Stable 7.3.11.0 (0MBCCNDC)
That's what I see when I got to About Phone
Hi there. I've the same MiMax (32GB) as yours, also bought from Qoo10 yesterday and with the MIUI Global 7.3 Stable 7.3.11.0 ROM. Spent the entire night trying to figure out how to flash to global ROM via System/Recovery/Fastboot method but all failed.
Until I saw the post by rECKleSSfElla below and followed the steps to flash to the latest Global Beta ROM. Thank god for this thread! The actual flashing took less than 5 mins for me.
Great info/tip above. I'm now a proud new owner of the Mi Max running MIUI 8. :D
Where to get tempered glass screen protector ? i haven't got mine yet, seems the tempered glass screen protector sold on market is not full screen ?
I'm also looking to get a glass SP. Any good ones I should look out for?
Thanks!
ferocity
Thanks!
If you guys dont mind applying the glass sp yourselves, i have an extra set of full screen glass sp(gold edge) + soft tpu transparent case bought from taobao to let go. Price will just be slightly above cost as i have to factor in forwarding charges. Deal at serangoon mrt. If interested do drop me a pm.
link to the glass sp: https://detail.tmall.com/item.htm?id=531825958585&toSite=main
jazzman80
tried the global ROM 7.5.3 ,stuck at bootloop upon restarting the phone.
I have sacrificed much of my sleep time on this. by trying the different versions of ROM.
anyway, I have tried looking for 7.3.11 .tpz but found only the recovery ROM.
went back to 7.3.14 china ROM, installed everything from the start.
at least I can set nova as default launcher on 7.3.1x
can't do that on 7.5.x
and I realized the default music Player is consuming over 150MB of RAM.
so I installed poweramp.
so yeah, on china ROM.
khaine
Urgh...failed at 58s with "Not enough storage is available to process this command. (0x80070008: Max buffer sector is 256)
Tried it twice. Made sure I did the "Disable driver signature enforcement" as well.
Some forums I found says to try to use another PC to do this?
My notebook is running Win7 Pro 64bit
Edit: Running it 3rd time....*fingers crossed*..passed 100s already
Update: Urgh...failed at 1500+seconds...same error
Any suggestions?
Mr. Bushido
64gb and 128gb cpu is sd652.. So different ROM
Yep, cos I went to the MIUI forums and saw that they only have global ROM for 32gb model. So what's the best course of action to take if I get the 128gb model? Anyone here bought 64 or 128gb model? Pls advice.
Nakedtoes
64 or 128 only China rom.. I dun think even got miui8 beta rom
rECKleSSfElla
India haven start selling 64/128gb variants so there wont be a global rom out for those variants until they are officially available in india. Best course of action is to wait, or buy now and flash to china stable rom.
rECKleSSfElla
Any suggestions?
Try flashing on a pc instead? If you got no acccess to a pc, then it will be tricky to pinpoint the problem.
First, redownload the miflash beta from another source. If you have a mi account, log on and download it from the miui eng forums
http://en.miui.com/thread-281979-1-1.html
Next, download the latest global rom fastboot version here(just released today, supposed to fix those wifi issues with india sets)
http://en.miui.com/thread-324576-1-1.html
Flash as per normal and see if the issue persists.
Otherwise, you can download and flash the miui 8 beta rom and see if that works for you.
http://bigota.d.miui.com/6.8.4/hydr....4_20160725.0000.28_6.0_global_f040cad0f1.tgz
