Xiaomi Mi Max
Nakedtoes
Brandless one, the $4.90 one from smartcell. Didn't like that it wasn't full coverage at first, but after using for awhile, got used to it already, quite okay with it. Noticed the full coverage one actually still has some border anyway. Rather it be transparent.
The clear one got white border leh doesn't stick to sides.
garychengjw
Simple steps...
1. Dl official global rom
2. Unzip it
3. Open miflash beta, select unzip rom parent folder, check "clean all"
4. Shutdown phone, then press vol+, vol- and power button at the same time. Phone will boot with vibrate and empty screen.
5. Connect phone to pc, wait for detect, then press refresh on miflash beta. Once detected press then flash button.
6. See screen and once ok, disconnect phone and restart
7. Wait for phone setup itself and voila, enjoy ur phone
Thanks for this tips! Flashing on my 128GB :s13::s12::s12::s12:
eurororfd2r
Was about to order 64G @$325 and sp@4.40 but no discount voucher:( guess still can wait.
Check if flash phone to global rom, if want to reset phone to factory setting after long useage (1yr) then we have to re- flash again after reset?
Nakedtoes
Scb $30 off? $295..good price.
kandinsky
Got pic? Mine has no white border though, unless what you're referring to is the section of the glass that doesn't 'stick' and thus looks different at certain angles when the phone is off? Doesn't make it white leh.
For me, the whole thing is still clear, so it's not visible when the phone is in use, so not an issue for me as it looks invisible on the screen.
Nakedtoes
Yea it is what I mean...
kandinsky
What is the voucher code?
https://www.sc.com/sg/credit-cards/the-good-life-privileges/#G1bs6jHz
