Xiaomi Mi Max
icefox2004
Thats great to hear. One question, can I use a tablet 4g data only sim on sim1 for data and another sim on 2 for calls?
If that is possible it's time to "throw" my ipad out the window :s12:
Yes you can do that. There is a setting for you to choose which Sim is for data and which Sim is for call.
jazzman80
just realized that the doze feature is related to the optimization setup.
maybe that was why the depletes of battery every hour.
have to test...
Oinkize
hi ,
can anyoneshare with me the url and data rom file you use? i plan to try out this weekend to flash it.
many thanks.
If your china rom is the modified version, try to go a few pages behind where i have posted links to flash to official china rom and gapps...
i1magic
I also found one eBay and ordered it already. Will test it out when I receive it.
Item : 2in1 Capacitive Touch Screen Stylus Ballpoint Pen For iPhone iPad Samsung Tablet
Price : About SGD$3.10
Source :
http://www.ebay.com.sg/itm/35179331...49&var=620705510750&ssPageName=STRK:MEBIDX:IT
The above stylus is used with the transparent disc membrane on it?
Sent from miMax using GAGT
Yes. Apparently, the transparent disc is to prevent scratching on the screen. From the video, it seems to be ok.
Anyway, I ordered liao. Will test it out and post review.
i1magic
Posion by xiaomi max. Will there be more users switching over after seeing this thread? I am one of the converted ones.
I was using Redmi Note 3 and ordered a Mi Max. Was planning to have more time to test it out.
But my wife's Note 4 suddenly died. So have to do immediate migration for her and I have no choice to switch to Mi Max also. Other than the screen, love the battery life.
KingOfSbw
side track abit, i used shopback for my mi max purchased on lazada 11 Aug...till now it is not in my pending list...i though the tracking can be done within 2 days? Almost 1 week liao leh
any bro can advise?
the tracking are 2 days or 15 days ar?
kandinsky
any bro can advise?
SOP is to file missing cashback and see whether they can trace it for you.
https://www.shopback.sg/help/contact-us
Oinkize
any bro can advise?
Mine reflected in pending after 12 hours.
You may want to follow kandinsky's advice to file missing shopback...
kandinsky
thanks guys will do that
btw the current posb/dbs 12% cannot be used for shopback ...cos its for purchase in app only
jus say fpr desktop there another code 10%
That's why do a comparison for your particular purchase, and see if 10% + shopback is more worth it vs 12%.
Basically, since it's capped at $20 anyway, anything above $200 like the mi max, buy on desktop better since either way, you still get $20. And you can apply shopback somemore.
Personally I rarely use the app 12%, usually go for desktop 10%, esp if non electronics item, 9% shopback.
kelvinti
My 32GB Mi Max Silver is on its way. Can't wait to surprise my chiubo.... I didn't tell her that I have managed to order a silver at $269 for her... Kekeke..
Oinkize
She will give you good good one at night when she receives the phone...
