Xiaomi Mi Max
kelvinti
huat ah, ,whr to find protector n case!!
Nice! :)
Must post picture here to share the joy when you received it! :s22:
Oinkize
I bought my Mi Max via Lazada on my smartphone but going to Lazada app directly. But I don't see any cashback in my Shopback account leh.
Did I miss some step?
I think shopback only works with browser and not app?
Unless there is a change in t&c...
KingOfSbw
purchased in lazada app not valid for shopback leh, anyway jus $5....u need $10 min to cash out
ralliart_ray
How to screenshot in max ah? Volume down n power button together doesnt seems to work. Lol me nooob andriod user
kweeli
I'm realized most people are getting 32GB model instead of 64GB model. Is there a reason why other then 64gb is not international model.
I'm plan to get 64GB model... wanted to know more before place my order.
Thanks.
kandinsky
That method works for me. Press and hold for a few seconds.
The other method is to use the screenshot button in the notification centre (MIUI calls it notification 'shade').
Swipe down from top, then swipe left, then you should see this, look for the screenshot button
Another way is to play with the 'quick ball' feature, it lets you add a screenshot shortcut.
Nakedtoes
Quick ball still very infant for more advance one is pie control from Playstore. Basically I can use mi max 1 handed..
micgoh
Thanks.
Hey bro been a Long time ! How have you been?
DRAGONGUY
Thanks.
Because most want global rom "out of the box" and simply 64gb they may find trouble installing google play which i find very easy, but some just dont get it work.
However, IMHO, it seems like 32gb having the most "common problems" so far. In miui forums, i seldom see ppl post about 64gb or 128gb problems... maybe got some unknown bugs in sd650?....
DRAGONGUY
My guess is that Global rom will be rolled out for 32GB only as the 32GB version is the only International model at the moment!:s8:
India still has 32GB only and there isn't any announcement for the 64/128 international model up until now!
The 64/128GB are still considered a product for China domestic market only! ;)
However, I hope that I'm wrong for the benefit of our 64/128GB early bird Olympic champions....:D:D:D
Well if, i really mean if, let's say no global rom for 64gb n 128gb, i will just stick to china rom stable or official stable of cm rom. To me china rom not an issue. The worst just root it, set the default appstore to google and remove all the chinese bloatware.
But so far i see the chances very slim for not having global rom ba (i may be wrong).
DRAGONGUY
Same i can handle mi max at one hand at times, so far i nv like the quick ball thingy, maybe i like my screen to be "clean".....
Nakedtoes
Pie control is good it is hidden unless u slide finger from edge.. Damed slick and useful
