Xiaomi Mi Max
heng_ah
Flashed my mi max to global beta rom
v6.8.9
but how come cannot see the change log
It says
Sorry you dont have the permission to access the update log
Please try to login in the system with an authorized Xiaomi ID
but i have login the Mi account on the phone
Anywhere else to log in?
Updated:
Fixed.
Now shows the changelog
I flashed from miui8 global stable to miui8 global beta (developer) v6.9.8 rom too becoz I need root access. I cannot live without Titanium Backup (to freeze/uninstall bloatware) and AdAway (for obvious reasons, ad free).
- applied for unlock of bootloader on Friday, received sms approval on Monday.
- flashed twrp recovery, rooted with SuperSU
This phone is superb. :D
Now, one thing is missing : third party music effects. I used to use Awesome Beats with Redmi Note. It doesn't work with miui8 :(
kelvinti
Well... being a beta... So,...you know..
Ndrew
Pokemon update buddy version will not work on rooted mi max. I already side load and got the incompactible message. Ya quite often mi max will hang, the top left icon kept circling and sometime must reboot than the pokemon come out. Everyday was catching lapras and nothing on my mi max, reboot and than it came out.
Sent from Samsung SM-T815Y using GAGT
heng_ah
Yup, heard about it. Apparently Niantic will check if android OS has been rooted or not.
Good thing is I have quitted Pokemon Go. :)
DRAGONGUY
Explained very thoroughly, Thank you!
Meaning local telco hasn't turn-on VoLTE support for mi Max. I didn't know telco must individually grant cellphone models on volte access.
Then I must switch bk to 3G on my Max. Thanks again.
There's no need for u to switch to 3g. Let the phone handle itself.
kandinsky
uh huh..so its heng suay if get a lemon set.
For the export sets from local sellers, if DOA will be covered under lazada's return policy, within 7 or 14 days.
No Warranty: If your product does not come with any warranty, then you can still benefit from the 100% Buyer Protection
http://www.lazada.sg/helpcenter/products-on-lazada/?boost=1#answer-faq-warranty-ans
If worried then get local warranty set at $349 - http://www.lazada.sg/xiaomi-mi-max-32gb-gold-8422303.html
emilfan04
ok just to update, now mi max working well. thanks for the advice on how to get google play to work! now just hope it doesnt explode..
i1magic
allanzzz
Or.
Open up miflash.
Power off your phone.
Connect USB cable to your phone.
Press and Hold both Volume Up and Volume Down and plug the USB cable to the pc end.
You should heard a pee sound with black screen on Mi Max.
Release both the volume keys.
Your phone should now in Fastboot mode.
Start the sequence of using miflash to flash the rom to your phone.
Haha the pee sound sounds weird.
Sent from LGE LG-D855 using GAGT
azbyza
Roughly how long does it take to charge from say 20% till full?
I've tried to test from 2% to 100% only once because it takes so long to drain the big battery down. It was about 4.5 hours using the supplied charger. Hence from 20% to full would proportionally be about 3.5 hours.
I'll usually leave it to charge overnight. Even if I forgot to charge overnight, it's still ok if the battery is more than 60% charged because that will still last me more than a day. When fully charged, the big battery will last about 2 days.
That's the advantage of a big battery.
ahhian
Thks for your reply. Does it have any kind of quick charge technology for this phone?
