Xiaomi Mi Max
touchme
Correct me if wrong, but the scroll screenshot doesn't work on many apps, and laggy on browsers (tends to hang when scrolling ss, on beta)
Bobby Goh
Nilkin now has TGSP for Max as well. Just ordered 2 pieces but need to wait about 2 weeks for mailing.
kandinsky
Wow! Just learnt new features especially the quickball shortcut (look at 8). Now can fast fast lock screen.
Can even use 2 whatsapp. Cool man.
http://en.miui.com/thread-303005-1-1.html
Cool read.
Noticed this part seems wrong tho. The second space on mi max can be unlocked with fingerprint. I set this up for my wife when she wanted to try.
Cons:
Once activated, a notification of switching to first/second space cannot be cleared.
For phone with fingerprint sensor, second space cannot be unlocked with fingerprint.
kandinsky
FYI, they've had it for awhile already. Unless you're talking about a different one. The nillkin one that has been out awhile is non-full coverage, which a lot of ppl don't seem to like.
http://www.aliexpress.com/store/pro...-Protector-For-Xiaomi/342812_32669485899.html
Bobby Goh
Yes, that's the one. From the image, though it's not full coverage, it's not like those random brand where the gap is as big as 1/2 cm. I can live with that.
SPEED
i think till now dont have a clear glass protector that covers swee swee with no gap
need to wait for the china makers to come out with new revision of the protector
charleslee
kandinsky
I think what bothered people more wasn't so much the gap, but the 'halo' effect cos the edges don't stick to the curved edges.
It's described in the nillkin graphic as "it will be white side when you put screen protector with phone together".
Just FYI la, no saying it's a bad TGSP. When I had it, it didn't bother me that much cos when the screen is on it's not really visible, just that depending on your environment and pockets, it might start to collect some lint/dust after some time.
Something like this (pic not mine)
charleslee
BTW u guys who've been actively changing phones, were there another phone or model that had these "lack of proper SP" at first? Roughly how long did it take, for manufacturers to come up with" PERFECT" ones?
Nakedtoes
This phone with curve screen very hard got perfect one... U get phone with flat screen lor..the screen protector (full coerage) is close to perfect. Can't see that I paste.. No rainbow effect also.
jace88
There's still no decent screen protector for s7 edge unless you willing to go case-less. That being said the ones which duplicate the front fascia (i.e. don't just cover the glass bit) tend to only have adhesive on the non glass bits making them less likely to stick on long term I found.
